Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Richland's Homebuilt Mill/pictures/first cut!!!  (Read 10850 times)
Offline RichlandSawyer
  • You hurt'em, You hurt'em BAD
Re: Came inside to say HI/pictures
« Reply #20 on: December 03, 2005, 12:23:14 pm »
D Frederick,
They are only 19 inch wheels but i designed the guard to take 26 inchers ifi decide to upgrade. I actually started designing before i ever saw a cooks mill but you are right it does look a lot like there mills (i guess great minds think alike). The wheels did come from cooks i did some research and really liked the way they balance there wheels. Not knowing much about band mills i have managed to gleen from all posts here and on other message boards that a smooth running blade is pretty important.
Again thanks for all the nice comments, it started snowing again this morning, its colder than three day old doggy doo and my boiler ignition controller went out last night so i better get it running, wifes getting cold. If i can scrape up more pphotos i'll try and put some up later today.
Every log i open up, a board falls out!!!
Offline lamar
« Reply #21 on: December 05, 2005, 12:46:04 am »
richland, how did Cooks balance their wheels. I have one(idler) wheel that wheel they balaned it the drilled about 2 or 3" of holes in the root of the sheave and it squeezed the sides of the angle in so the tire has a slight hump in it. Still havent firgure out how to fix.Its not real bad but iratating. Im just about to the end of the first set of tires need to get new ones before I hit steel.
« Reply #22 on: December 05, 2005, 11:26:36 am »
Lamar,
Cook's doesnt use rubber tires they are all steel wheels. That way they are not effected if you use petrochemicals for lubrication such as diesel or kerosene. The drive wheels are chucked into the lathe using the taper lock bushing that comes  with the wheel and then the bushing and the wheel are both marked so when you assemble it on your mill they go back together the same way they were balanced.
As i stated earlier i really have no experience with bandmills but i do know a lot about industrial machinery and this makes good sense to me. Also i went with a spring backed tensioner instead of hydraulic because i think without the rubber tire on the wheel there would be no shock absorption using a hydraulic tensioner.
Could cause  a real problem with blade breakage.
If anyone else has any input on this subject i would really appreciate hearing from you. I would hate to get this mill done and find i i've been smoking corn silks this whole time and end up with a 3000lbs. paper weight.
Thanks RS
Offline ronwood
  • Enjoy Making Sawdust !!
« Reply #23 on: December 05, 2005, 12:06:08 pm »
RichlandSawyer.
One of the things that I like about using a Hydraulic tensioner with gauge  like Woodmizer has is that you can get a pretty good idea when the blade is getting warm and stretching.  Correct me if I am wrong on this but it appears to me after the blade has been on a while that the loss of pressure ussally indicates that the blade is getting dull or you need to have some lub on the blade to clean it up.
Just my thoughts
Ron
LT40HG25 Woodmizer Sawmill
LX885 New Holland Skidsteer
Offline woodbowl
  • Making old fashion, oblong dough bowls, sure is a lot of fun
« Reply #24 on: December 08, 2005, 02:35:00 pm »
Hey Richland, how bout' an update on that fine mill your building? I know Christmas has probably got you runnin'. We're sorta' waiting on some more pics.  ;D
Full time custom sawing at the customers site since 1995.  Added homemade hydraulics to a 1988 manual WoodMizer LT40.
Re: Came inside to say HI/pictures/Jan.update
« Reply #25 on: January 09, 2006, 12:33:22 pm »
I now have a rolling trailer for the mill head and was all excited about getting the head up on it.
Then i realized that if i put it on i cant get it back into the garage to work on it. The head is about 2 inches too tall to fit back in. Between the holidays and work seems like i've passed myself on the highway a time or two. I have to tell you i'm really starting to develope a complex over this mill building project. Almost everyone that comes by and sees it says the same thing ( You built that yourself?!?!?).
Just what are they trying to imply? Anywho,
Waiting on parts right now Harbor frieght had leveling jacks on sale but they sold all but three the day the sale started, guess theres a lot of trailers being built around here, suposed to get a new batch on the shelf tomorrow so i'll swing by the store and see if they aint pullin my leg. The wife says hey to everyone, she enjoys reading the banter between everyone. And for some reason she seems to have a  thing for Bibbyman, not sure what thats all about, she says he reminds her of Red Green.
Well i really have to go the sun just came out and i'm gonna run outside and stand in it. havent seen that big fireball forever.
Offline woodbowl
« Reply #26 on: January 09, 2006, 01:05:31 pm »
  ......... if i put it on i cant get it back into the garage to work on it. The head is about 2 inches too tall to fit back in.
Did you try letting some of the air out of the tires, just to get it in and out? ................... We're still waitin' for pics................ at this point we'll take any pics, even a flat tire.  ;D
Offline Murf
  • The pitter-patter of little feet..........
« Reply #27 on: January 09, 2006, 02:52:56 pm »
Or run the head to one end or the other an tip that end of the trailer down so the head clears the door frame?
« Reply #28 on: January 09, 2006, 03:44:43 pm »
Hey Fellars!!
I pulled the trailer outside and took some pictures for ya.
Got some good closeups of the logdogs.
Here is the trailer
This is the first log dog i installed
This is the second log dog its still laying on the bench waiting to be installed
Offline customsawyer
  • www.thecustomsawyer.com
« Reply #29 on: January 09, 2006, 06:49:53 pm »
Welcome to the forum.
I am getting a little jealous though as you seem to be moving right along with that mill and I can't seem to make any head way on the projects that I have going. Seem to be spending to much time making sawdust. Then again theres no way you can spend to much time making sawdust.
« Reply #30 on: January 24, 2006, 03:58:49 pm »
Hello to all!!
UPS guy just came and he left me a brand new set of blade guides!!!(finaly something i didnt have to build myself) tomorrow its off to the steel supplier to get tubing to make slides for them bad boys. I finaly settled on a design for log clamps and gonna work on those at the same time as the roller guides. I like to keep two projects going at once that way when i get stumped on something i can walk away clear my head while doing other things. All the leveling jacks got welded on and in my spare time i'm still trying to come up with some earth shattering new invention for getting logs up on the bed. i'll be sure and snap some pictures as the blade guides go on. I'm planning on using UHMW polyethelene for linear bearings on the roller guide adjuster, hopefully it will slide easy with no side movement, keep your fingers crossed.
I would also like to say that with all the comments flying around about MD I personaly would like to give a big pat on the back to the fine folks at Cooks Sawmills, They have done me well with bandwheels and blade guides and have been very kind and helpful. A real class act, the cook boys should be proud of there operation. I'm not sure if they ever read this forum but if they do you folks should consider a sponsership.
One last thing, I would like to thank Jeff and all the members of this message board, I could have spent a million dollars on books and never gotten the amount of information i have received from you folks. I dont know how someone could ever say thank you enough. I have been reading old posts and archives on here for about a year now and still find something new and interesting everytime a do a search.
RichlandSawyer
Offline Grappletractor
  • Grapples RULE
« Reply #31 on: January 25, 2006, 11:15:59 am »
RichlandSawyer ,
Any guess yet as to the material cost you'll have in it when finished ?
  • Grapples RULE
« Reply #32 on: January 25, 2006, 12:24:19 pm »
Re: Came inside to say HI/pictures/Feb.Update
« Reply #33 on: February 12, 2006, 09:35:46 pm »
Hey Folks,
   Got them new blade guides almost on so i thought i'd share some pictures.
Re: Came inside to say HI/pictures/Feb.update
« Reply #34 on: February 13, 2006, 10:41:57 am »
Hi Shawn,
    I'd be happy to give out that info. The bandwheels came from Cooks sawmills, you can get there prices online, the wormdrive gearbox for raising the head came from ebay, i think it was around 40 dollars. the guides also came from cooks, trailer parts are Northern, and bearings and pillow blocks all came from a couple farm stores, also the weld on sprockets came from the farm stores. I could have gotten the bearings cheaper if i ordered them online but i really wanted to see them in person before i purchased. The steel for the project came from a farmer who sells steel seconds he buys from streel distributors. The 3x2 tubing cost me 40 cents a pound but it was rusty and took me hours with the palm sander to clean it up. The small pieces of steel and shafts came from a local steel supplier, Took me awhile to find one that actually wanted my business. since i was only buying $75 to $100 when i went in most where very nasty to me.
Finally found a small place that the ladies at the counter are sweet as cream and were happy to get a $100 steel order.
If you have any more questions just ask!!
RichlandSawyer
Re: Richland's Homebuilt Mill/pictures/Feb.update
« Reply #35 on: February 13, 2006, 10:52:29 am »
Since this is my thread i decided to rename it to something more descriptive of whats going on in here.
The new roller guides need more welding they will be permanent. I have to say when planning this project the two things i was not looking forward to was the blade guard and the blade guides and i must say i was not dissapointed. The blade guides are hands down the most difficult pieces to attach to the mill. to get them rock steady while out in the middle of the balde is extremly difficult. If anything happens to the movable guide on there now i'm pretty sure i will change the design again. If you are building your own mill make sure you give this some serious thought and maybe start working on mocking it up before you actualy get to that part of the mill. The next challange is squaring arms and log clamps, i have a design for that just need some warm weather.
More in a bit.
Offline Coon
« Reply #36 on: February 13, 2006, 04:10:05 pm »
 8) 8) 8)  Everything looks and sounds like they are coming in place.  I thought about building a mill of my own some time ago.  While thinking and trying to draw up some plans I found a second hand WM for a decent price.  Had to buy it as I deperately needed a mill ASAP.  Would still love to build my own though but it'll have to wait..  Keep those pics a coming and take your time building.  Any project that large takes some major critcal thinking and will rely on that till the bitter end. ;) ;) 8)
Brad.
Offline kelLOGg
  • Good, fast, cheap... pick any two.
« Reply #37 on: February 13, 2006, 06:02:56 pm »
I was impressed with Cook's mill, too - I added my own options but I did not have the oomph to build it from the getgo. Looks like you have done a fine job.
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
« Reply #38 on: February 21, 2006, 11:49:51 am »
Goodmorning all;
    I was just stopping in to take a little poll, I was doing some calculating over the weekend and given the components i have on my mill i determined my blade speed would need to be 5300 fpm for minimum resonance. So i was just curious what other people are running for blade speed in relation to wheel size and guide type. Any information would be greatly appreciated for future reference. Thanks!
Offline loudsam
  • " You call, we haul, that's all"
« Reply #39 on: February 21, 2006, 12:08:28 pm »
Welcome to the forum Richland! ;D  That is a nice looking mill, and it looks like very good craftsmanship.  Everytime I look at my mill I wish I would have built it myself.  I will build one someday.  Maybe I can get the plans from you.  Happy sawing!!! 8)
Doug
Saw Anywhere!
