Get your Forestry Forum Hats while they last!
Could be the coil ? Ian
Another long shot, but could it possibly have H-2-0 in the G-A-S? For Russ, this is water, Ken
Does it stop like you shut the switch off or like it's running out of fuel? If you have proof of purchase , you're the original owner, and you didn't purchase it under a business name. We will warranty it for you. If you bought it from us and it's a warranty, we'll pay the shipping back to you.
The coil? Would it still spark? Plus, wouldn't the plug be all wet when I am pulling and pulling on it?
Sounds like a fuel tank vent problem. Fill the saw with fuel. With the saw laying fuel cap up, disconnect the fuel line. The fuel should flow at a steady pace. If it slows down to a drip or stops, open the fuel cap. If the fuel takes off and runs again, the problem is probably the tank vent
da other heat sensitive failures are da ignition module and compression. With da module it'll quit in da middle of a cut like youse guys tuned da switch off. It won't restart right away but, if youse guys let it sit 5 minutes it restarts like nothing happened. With da compression problem da warmer da saw eh, gets da less power it has til it stops. With either one of these da plug should be getting wet when youse guys crank it. da little white disc youse guys see when youse guys look at da tank vent is like a soapstone material. If it gets oil soaked it won't let enough air through. Your right about craking cap as it starts failing should clear it up til da vacuum gets ta great again
