check your fuel line to the tank and make sure there are no blockages, cracks etc. turn the fuel mixture screws all the way in (count the turns) then loosen them back to the original position. If that doesn't help get a carb kit, you might have a hole in the little diaphram in the carb, gummed up jet, or dirt in there.
