Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Skid road bridge building?  (Read 2495 times)
Offline David_c
  • treat people the way you want to be treated.
« on: October 13, 2005, 10:09:40 pm »
I am going to be starting a job in about a month or so. where i am going to need to build a temporary bridge over a brook about 8' wide with about 2' high walls. Comming out with hitch i will be comming down a hill. I have never built a bridge before so could really use some help.  Thank you in advance!
Offline GregS
  • I just want to be in the woods...
Re: Skid road bridge building?
« Reply #1 on: October 13, 2005, 10:24:30 pm »
David,
I was looking at a pretty cool pdf document on this subject.
http://www.umass.edu/nrec/pdf_files/skidder_bridge.pdf
Greg S
Offline David_c
« Reply #2 on: October 13, 2005, 10:48:25 pm »
Thanks i will look. I thought i would thank you before looking becuase pdf take a few to load on my slow computer.
Offline beenthere
  • EIEIO
« Reply #3 on: October 13, 2005, 10:55:20 pm »
David_c
What are the " 2' high walls "  ??
Here is a pic of a temporary bridge idea shown at a recent Forestry Field Days. It is just in a ditch to show the construction, of 4" plastic tubing with 3" planking chained together on top of the tubing. Holes were drilled through the width of the planks and log chain threaded through and tightened with a chain binder.
Offline David_c
« Reply #4 on: October 13, 2005, 10:56:33 pm »
Thanks again Greg. But that seems a bit more involved than i was looking to do. Not that i wouldn't if there isn't a quicker less expensive way of doing it.
Offline David_c
« Reply #5 on: October 13, 2005, 10:58:57 pm »
Walls are where water has eat away at the granite.
Offline Max sawdust
  • If it's got to do with making sawdust; count me in!
    • truetimbers.com
« Reply #6 on: October 14, 2005, 04:53:00 am »
Hi,
What is the distance to span?  I am no engineer ::) but I recently cut 5"x6" oak timbers for a bridge that was being built to span a 3' culvert.  The bridge will be 15' wide.
max
True Timbers
Cedar Products-Log & Timber Frame Building-Milling-Positive Impact Forestscaping-Cut to Order Lumber
Offline David_c
« Reply #7 on: October 14, 2005, 10:19:40 am »
Brook is about 6-8' wide. Going back in this weekend when this rain stops. only saw it for a few minutes on walk through with forester. So kinda going by memory which (what was i saying) Oh yea fading ;)
Offline Ron Scott
    • Ron Scotts Web
« Reply #8 on: October 14, 2005, 11:11:04 am »
See the Forum Thread on Bridge Building,
http://www.forestryforum.com/board/index.php?topic=9855.0
Also contact your State DNR or Extension Service to see if they have a manual on Best Management Practices for timber harvesting. They often show approved methods for doing water crossings, both temporary and permanent.
~Ron
Offline David_c
« Reply #9 on: October 14, 2005, 12:15:25 pm »
Thanks Ron for the link and now you mention it i know i have something around here from a BMP class i took.
Offline Bill H
« Reply #10 on: October 14, 2005, 02:57:27 pm »
In Kentucky's BMP's on page 19-20 they have a simple bridge that has worked for me and simple to build on site:
Link to Kentucky BMP's
Bill
love to play in the woods
ECHO 660EVL
Timberjack 230D
Cat 941
Ford 7600
Offline David_c
« Reply #11 on: October 14, 2005, 06:15:58 pm »
Thank you for link Bill.
Offline Ed_K
« Reply #12 on: October 14, 2005, 08:49:35 pm »
 I have one to build this next week. Going to use some crooked w/pine logs 15' long and put into the brook running the same way as the water. Then I'll use the tops cut 12' and lay in like planking. May use some of the junk hemlock too. This bridge will have to be removed next spring before high water.
Ed K
Offline David_c
« Reply #13 on: October 14, 2005, 10:48:27 pm »
I gotta say i hate trying to post pics. This is a pain. Maybe third time is a charm. Anyway here is the description of brook crossings i found from the class i took. Man do i hope this works this time.
Offline David_c
« Reply #14 on: October 14, 2005, 10:50:32 pm »
I would really like to know why i couldn't post when attatchments where there but as soon as there gone no problm? If they aren't to big to upload then i really don't see why i am having the problm.
Offline Furby
  • Blurb....
« Reply #15 on: October 15, 2005, 12:00:00 am »
Take a look at this thread for your pic posting problem. ;)
http://www.forestryforum.com/board/index.php?topic=12416.0
Offline Timburr
  • Welsh border timber grower and miller.
« Reply #16 on: October 15, 2005, 07:39:41 am »
The forwarder drivers who operate in our Crown forests are issued with a multiple pipe type structure, that is placed in a brook or ditch in a matter of moments.
The 'pipes' are flat sheets (about ½" thick, tough, neopropylene type plastic) rolled into seamless 'spirals'. The idea of being seamless allows flexing rather than splitting when a heavy load is run over them. I think they are about 6" in diam. and 20 or 40 are used depending on the width of the crossing. I can't remember if bundles are strapped together or not.
Drivers simply load them out of their bunks, like logs, into the stream and drive over them.
I don't know what they would be like skidding over, but I guess something could be put on top to prevent them getting ripped out.
Sorry, no info. on manufacturers or suppliers and if you folks haven't got them over there, then it's a good opportunity for a manufacturer. They are a  8) product
Sense is not common
Offline David_c
« Reply #17 on: October 15, 2005, 06:03:26 pm »
I'll try this again. We'll see
Offline David_c
« Reply #18 on: October 15, 2005, 06:05:15 pm »
WOW that worked great. That isn't how i had to do it before. At least i don't remember doing it that way. Thank you for the link Furby.
Offline Furby
  • Blurb....
« Reply #19 on: October 15, 2005, 11:00:06 pm »
Saw Anywhere!
