If the bearing failed soon after it was installed, chances are some or all of the balls were out of round or not all the same diameter. Making good bearings requires super precise grinding of balls and rollers.
The grinding equipment to mass produce large quantities is now readily available around the world, but knowing how to run it takes some learning, AT YOUR EXPENSE.
