Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: using your wood waste slabs and sawdust etc  (Read 2175 times)
Offline Quebecnewf
« on: September 24, 2005, 08:29:22 pm »
Is there anything out there in the boiler line that would allow you  to burn your slabs and generate electricity. I could see something along the lines of your sawmill is connected to the electrical grid and as you saw you would fire up the boiler and feed in the slabs throughout the day. All the power you produce is used up by your mill and any extra is fed back into the grid. If you don't fire up the boiler you just run of the grid as normal. Am I dreaming in colour or is this type of thing possible in a mid sized operation.
Offline Brad_S.
Re: using your wood waste slabs and sawdust etc
« Reply #1 on: September 24, 2005, 08:56:44 pm »
A friend looked into co-gen as you describe and was frightened away by the cost and the rules that accompany such a venture. Say the word 'boiler' and you get all sorts of regulatory and safety agencies excited. I don't know the specifics of what transpired, but he was pretty bummed about it.
Offline sawdust
    • Dream Dovetail Co.
« Reply #2 on: September 24, 2005, 09:15:47 pm »
A buddy looked at building a gasifier to fuel a 460 ford to spin a genset. Alberta government does not look happily upon putting power back into the grid. They prefer that we simply purchase it from big business and keep our mouths shut. end of rant. Short version is, too many hoops.
sawdust
comforting the afflicted and afflicting the comfortable.
Offline farmerdoug
« Reply #3 on: September 24, 2005, 09:16:47 pm »
I think that you should look into the wood gas generator that Mother Earth News built in the 70's or 80's.  You use the wood gas to run a engine to power the generator.  I still have that copy somewheres but that would be a project in its self.  Look up their web site and they probably still have info on it.
Farmerdoug
Doug
Truck Farmer/Greenhouse grower
2001 LT40HDD42 Super with Command Control and AccuSet, 42 hp Kubota diesel
Fargo, MI
Offline spencerhenry
« Reply #4 on: September 24, 2005, 10:25:43 pm »
in colorado, "green" power is in demand. people have the option to pay more for electricity generated from wind power. recycling slabs, saw dust , and other waste is also probably good. here in co, if you generate power beyond your needs, i believe the utilities are required by law to buy it from you. i know there are tiny hydro generation units that do this.
Offline woodbowl
  • Making old fashion, oblong dough bowls, sure is a lot of fun
« Reply #5 on: September 24, 2005, 10:30:43 pm »
Here is a thread about gasogen generators that you may want to check out. I thought there would be more interest on the subject. I guess fuel isn't quite high enough yet.-------------Anybody know how to make sawdust burn hot without smoldering?
http://www.forestryforum.com/board/index.php?topic=13851.0
Full time custom sawing at the customers site since 1995.  Added homemade hydraulics to a 1988 manual WoodMizer LT40.
Online Fla._Deadheader
  • Linda Vista, Costa Rica
« Reply #6 on: September 24, 2005, 10:39:43 pm »
 Suspend it in the chamber with air.
« Reply #7 on: September 24, 2005, 10:51:16 pm »
Deadheader is right.
My cousin used to work for St. Regis Paper here in town.  They would visit the carpentry shop frequently to get the sawdust from under the saws and squirrel it away in big boxes in the boiler rooms.  One of his jobs was helping to fire the boilers.  They were fired with wood chips and bark.    They called the sawdust "White dynamite".   When the fires got a little too low and the boilers needed a quick kick,  they would throw shovel fulls of White Dynamite into the fire box along with a strong burst of compressed air.  He said it would get super hot immediately, even before you could back out of the way.  The boilers would be brought back to temperature right then.
If you throw a shovel full of sawdust on a fire without dispersing the particles, the fire will go out.  The sawdust may smolder but won't burn.
Offline Furby
  • Blurb....
« Reply #8 on: September 25, 2005, 12:27:47 am »
Yup, but they are allowed to charge you a processing fee per month. So you'd have to produce a lot to cover the fee, before you make anything.
Also you must provide the equipment for the hook up, saftey shut downs and so on.
And the power you generate must be "clean" and of the apropiate "wave".
Long list of hoops to jump through to make it work.
Offline Ron Wenrich
« Reply #9 on: September 25, 2005, 07:43:40 am »
I helped site a co-gen power plant.  It was an air suspended system with a fluidized bed.  Rule of thumb was 10,000 tons of woodwaste/Megawatt/yr, if I remember correctly.  Figure out how many tons you generate, then go from there.
We signed a contract with the local utility and we had to guarantee a certain amount of electricity on either a daily or monthly basis.  If you didn't meet that, then there were some pretty heavy penalities.  Our buyback rate was 7 cents/kw.  I'm not sure what that amount would be right now.
After you figured your potential income, figure out how much you could get for those slabs and dust without the other capital investment.  You might find out that you're better off without the extra boiler, unless you have a market for the trash steam.
« Reply #10 on: September 25, 2005, 07:57:58 am »
 When I was getting the backyard Gen system going in Arkansas, We would use a Synchronous Inverter, hooked into the Breaker Box. It would allow you to use your power first. Then, if you had extra, it would feed into the grid, turning your meter backwards. That was the ONLY requirement, aside from double throw switch box, to stop feedback when the grid was down.
  Sometimes, when you talk to the Power Company, you make it sound like a BIG operation, and then, the long list comes into play.
  Look into the Synchronous Inverter before doing any more figuring. That would be the easiest way, and requires no BIG list, unless you wanna become a "player".
Offline Furby
  • Blurb....
« Reply #11 on: September 25, 2005, 01:47:22 pm »
That was then, this is now Harold.
We can no longer do lots ot things we once did. :-\ :'(
« Reply #12 on: September 25, 2005, 04:36:48 pm »
 timely thread. today i finally had to do something about the slab and edging pile. while i dont do that much milling, slab disposal and handling sure seems to take alot of time. i have a wood stove, and burn as much as i can, i also give away as much as i can. what does everybody else do with their slab? i thought of renting a chipper, but that takes just as much or more time, and is also expensive. i burn in a big pile all that i can, but i cant burn here except in winter or spring. also, do custom sawyers charge a fee for disposal of slab?
Offline woodbowl
« Reply #13 on: September 25, 2005, 05:11:15 pm »
Not me, I saw on their site. ;D ;D  It's a big mess when I do occasionally saw on my site. I did the same thing you did. It may leave a bad taste to have little charges. I know it annoys me to pay to leave the old tire when I buy a new one, so I just take it with me. Hey, I know......... ::)
Offline Ron Wenrich
« Reply #14 on: September 25, 2005, 08:02:00 pm »
You can put a lot of material in a chipper in a short amount of time.  A lot depends on how easy it is to handle.  Before we had a chipper, we would stack our slabs and edging strips in a rack.  Then, we banded it for easier handling and sold bundles of slabwood.
When we started to saw more than the market wanted, we would chip on a Saturday for about half a day.
Another option is to make shavings.  The only problem is that shavers usually only take 4' lengths.  Shavings are good for poultry and cattle, but really are good for horses.
Offline Warren
  • Whatever you do, work at it with all your heart, as working for the Lord.... Col. 3:23
« Reply #15 on: September 26, 2005, 10:47:06 pm »
Mr. Wenrich,
I would appreciate if you could say more about "shavers".  I also have an issue with slab disposal.  I live in horse country.  No one wants the fine sawdust off a band mill.  But they are interested in shavings to bed horse stalls.  Are there any links or references to companies that build/sell "shavers" ?
All help appreciated.
LT40SHD42, Case 1845C, W&S Forklift, Baker Edger ...  And not near enough time in the day ...
Offline Ron Wenrich
« Reply #16 on: September 27, 2005, 06:03:33 am »
Jackson Lumber Harvester in Wisconsin makes one. http://www.jacksonlbrharvester.com/
I've also seen some that were home built.  We have one outfit that produces shavings for chicken houses.  Theirs will accept 15' material.
Basically, its a metal hopper that holds material and is run back and forth over a cutter head.  The cutter head is about 2' wide and is normally the same thing you see off of a planer.  Discharge to the bottom.
I saw one operation that used a homemade shaver, then run them on a conveyor under 8 heat lamps with a wire placed to turn the shavings.  It dried them out, and he went and bagged them.  Bagging system is very expensive.
Offline Frank_Pender
« Reply #17 on: September 27, 2005, 09:21:05 am »
A person could sure go wild with dreams at a place like that, Ron. 8) :'(
Offline Ron Wenrich
« Reply #18 on: September 27, 2005, 05:10:40 pm »
I had 2 of their mills and still use their log turner.  Down to earth company with good customer support.  Maybe we should get them to advertise.   ;)
Offline Russ
  • Will Work for Food
« Reply #19 on: October 02, 2005, 09:45:43 pm »
Seems like somebody would make a sawdust pelletizer for smaller quantity's of sawdust. I throw my sawdust away , seems a shame .
Saw Anywhere!
