Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: New Problem HELP! Possibly big onan troubles?  (Read 3576 times)
Offline D._Frederick
Re: New Problem HELP! Possibly big onan troubles?
« Reply #40 on: September 07, 2005, 05:42:13 pm »
Jeff,
Look for an openning that has a seat for the round end to seal against.
Offline pigman
« Reply #41 on: September 07, 2005, 06:15:25 pm »
In my opinion it goes in hole  G  in your picture. Ok, I don't know.   The reason I bought WM  with a diesel was to keep from having carb problems. ;)
Offline Furby
  • Blurb....
« Reply #42 on: September 07, 2005, 06:33:46 pm »
Just guessing from looking at the pic, but "B" looks like it might be it.
Look at the other half and see if there is something to indicate where it goes.
Just take the other carb apart and this time take note of where it falls out from. ;D ;D
Offline Jeff
  • Lead Administrator
    • THEE Forestry Forum
« Reply #43 on: September 07, 2005, 06:55:08 pm »
with a little help from wood-mizer and with the post from  D._Frederick  I narrowed it down to a pretty good guess.   None of Wood-mizer's books show the part that fell out. :-\
Furby, you dont want to know what I did before I made this post. :-[
I dont think the carb was the problem. When I had both of them off, I could turn them updide down, and try to blow into the fuel lines and the needles were doing thier job, No leak through that way, regardless, I cleaned both carbs again but put the old one back on. I then pulled the ful pump.  The hose going to the back was wet inside, althoug I could not get it to leak gas while blowing on it, I think this may have been the problem. I hope. I put the one on off of kevins engine, pumped up the bulb, and after changing the oil AGAIN, firesd it up. Started right up. Shut it down for a few minutes and it fired off quickly again, this was have way through the thunderstorm so I figured I would come in and get dry clothes on.   I did power it up a couple times and it seemed to be running smoother. I hope this is not just wishful thinking.  When it quits raining I'll go try to start it again. If it fires right off I think we have something, as anytime it has set in the past, it starts real hard.
Offline Furby
  • Blurb....
« Reply #44 on: September 07, 2005, 07:00:06 pm »
 :D :D :D :D :D
Sorry for laughing, but I can make a pretty good guess what ya did!  ;) ;D
Can't say I haven't done something like that myself................... ::)
Offline woodbeard
  • Sailors have sea legs, sawyers have board feet.
    • Dismal Guitars
« Reply #45 on: September 07, 2005, 07:19:56 pm »
I actually just had mine apart today beacause my engine seems to be running rich, too, so I was checking the needle valve in it.
I'm just going on recall, but I seem to remember the spring being in hole E.
Offline Jeff
« Reply #46 on: September 07, 2005, 09:29:08 pm »
Yep, E is where I ended up putting it, there is a small brass bin on the top of the carb that fits into the top of the spring.  THe thing started so, so far, so good.
Offline Rockn H
  • long way to go
« Reply #47 on: September 08, 2005, 12:34:55 am »
Jeff, you weren't trying to mess us up with F were you?  Looks like I see threads in that there hole. ;D
Glad it sounds like you got it figured out.  I'll have to remember that one since I'm running an onan also.  I would have never thought about the vacum operated fuel pump sucking gas back through the intake. ;)
Offline hawby
  • Just "Bearly" gettin' by ;-)
« Reply #48 on: September 08, 2005, 09:03:55 pm »
Jeff,
Did you say, "Rain?" What is that????? We are so dry down here. The weatherman keeps promising it, but the ground is cracking.....
Hawby
Missin' loggin', but luvin' the steady check...
Offline Furby
  • Blurb....
« Reply #49 on: September 08, 2005, 10:15:41 pm »
I hear ya Hawby!
Was wondering what that was Jeff was talking about.
Offline Jeff
« Reply #50 on: September 09, 2005, 12:32:31 am »
I bet we got close to an inch, but thats the first rain we had had since two days before the pig roast I think.
Offline Furby
  • Blurb....
« Reply #51 on: September 09, 2005, 12:41:12 am »
I think I've had less then 3" since the end of April or early May.
That was mostly in 2 or 3 storms.
East of here was getting dumped on a lot the begining of summer, I didn't get hardly anything.
Couple weeks ago my parents had a heavy storm that took down parts of trees in the neighborhood..........5 miles North, I had sunny skies.
It's odd when they are showing on radar that you will get hit in a couple hours and you think of all the stuff that you have been leaving outside without worry of it getting wet. You then go out and pick things up and ..................... no rain! ::) ::)
Rain is now out of the forcast for another week.
Offline ladylake
« Reply #52 on: September 09, 2005, 06:11:17 am »
Jeff  Did you give it a good workout yet? Running good?  The pulse hose to the fuel pump will always be wet, same as the oil cap or inside of the crankcase as that's where the air is coming from to run your fuel pump. Most likely there was a speck of dirt in the carb that you got out.   Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Offline Jeff
« Reply #53 on: September 10, 2005, 07:18:56 pm »
Still not right. I'll change carbs now.
Offline Jeff
« Reply #54 on: September 11, 2005, 09:52:04 am »
I ran the mill yesterday and cut to small red pine logs. Mill ran BAD while cutting.  THis morning I went out and changed the carb. I checked the oil and the level was good, but I think I detect the smell of gas.  I tried to start it, No fire.  Acted flooded.  I pulled the plug on the front side of the mill and it looked good, I pulled the plug on the back side and it looked good but wet. So, I decided I would crank the engine a couple times with the plug out. GOOD DANG thing I didnt have my face any closer. Must a blew at least an once of gas out.  Either that gas got in there last night after we shut it down, or it accumulated in the last cut or so when the engine felt like it was running on one cylinder.  You would think it would get sprayed out the exaust, but I guess, as liquid, how can it? Muffler goes straight up.
As soon as I blew that stuff out of the cylionder and put the plug in it fired right off. I am going to go out and saw another log in a bit. Hope its better. Dont know what else it could be now if it aint. Different fuel pump and different carb.
Offline Coon
« Reply #55 on: September 11, 2005, 10:11:12 am »
Well,  for all of those who are wishing for rain......hmmm...... come and get some.  We have had by far more than needed.  95% of the crops here are still out in the field and we have yet been able to pick them up.   On a normal year we would be nearing the 60-75% finished point but not this year.  We can't even swath alot of the crop that is in the low spots cause they is full of H2O.  In the past month or so we have had atleast 15 inches of the wet stuff.  Getting kinda depressing.   Especially when our barley that should have went malt is now only of feed grade because it has sprouted.
Offline Jeff
« Reply #56 on: September 11, 2005, 10:46:14 am »
Stopped to grab some late breakfast.  MUCH BETTER! I think the problem is solved knock on wood.
Offline woodbeard
    • Dismal Guitars
« Reply #57 on: September 11, 2005, 05:13:57 pm »
well, here's hoping you end up with plenty to knock on!  ;D
Offline ladylake
« Reply #58 on: September 22, 2005, 07:07:20 pm »
Jeff  Hows that Onan running?  Steve
Offline Jeff
« Reply #59 on: September 22, 2005, 07:42:41 pm »
Its really running well. It was all in that carb somewhere.  I may pickup a kit for it and rebuild it so I have it on the shelf.
Saw Anywhere!
