Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: could you use a variable speed electric motor for a power feed?  (Read 1660 times)
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
Re: could you use a variable speed electric motor for a power feed?
« Reply #20 on: September 02, 2005, 12:47:42 pm »
 No,  Amps is what you need and 12V @ 373 watts = 31 Amps. We have our feed drive set up, so, if we get bound up somehow, the motor pulley will slip, just like a clutch.
Offline Rod
« Reply #21 on: September 02, 2005, 01:15:42 pm »
ok ,90v x 1.0 watt = 90 amps,right?So  is that enough amps?I believe the contonller has an over load on it.
What I don't get is why does it say it has 90v?
http://www.baldor.com/products/product.asp?1=1&product=Gear+Products&family=DC+Gear+Motors%7Cvw%5FGearProducts%5FDCGearMotors&rpm=6
Gear Products | DC Gear Motors | 6 RPM |
Specifications: GP7304
Catalog Number:  GP7304
Specification Number:  27314E
Phase:  DC
Output RPM:  6
Torque:  150
Ratio:  600
Amps:  1.0
Insulation:  A
Rotation:  R
Enclosure:  TENV
Type:  73P
Mechanical Specification Number:  24A403Z071G1
Electrical Specification Number:
Offline Rod
« Reply #22 on: September 02, 2005, 01:22:05 pm »
OUTPUT RPM 6
  TORQUE (Lb-In)  150
 VOLTAGE 90
 RATIO:1
  HORSEPOWER 1/8
 CATALOG NUMBER GP7304
Thats what it says about the motor
Offline mike_van
« Reply #23 on: September 02, 2005, 01:40:59 pm »
It needs 90v DC -  Like AC motors that are 120 - 240, many dc are 90 - 180  DC.   This has to come from an inverter hookup,  you won't get it from the 12V DC that I believe Woodmiser uses.   Also TENV is totally enclosed NON vented - Most of these are intermitent duty - Like 10 - 20 minutes out of an hour - This will probably cook itself and go off on thermal overload running a carrige continuously.
« Reply #24 on: September 02, 2005, 01:41:27 pm »
 Read YOUR specs in the second post back from this one. It states 1.0 AMPS
  1 AMP is very little power.
  I don't understand why you have been given several viable ways to do what you want, and then, are hung up on this motor ???
  All those that have responded to you, are doing so from THEIR EXPERIENCES.  ::) ::) ::) ::)
Offline Jeff
  • Lead Administrator
    • THEE Forestry Forum
« Reply #25 on: September 02, 2005, 01:53:24 pm »
Harold, I am beginning to think that there are certain individuals that use this forum simply to entertain themselves by seeing how stupid they can be before we lose our patience and go comp[letely out of charactor for an understanding friendly and helpful forum. Well one certain individual, lets call him SYBIL, has made me create another personality, one I dont like and he wont either.
Offline Rod
« Reply #26 on: September 02, 2005, 01:54:25 pm »
Deadheader ,i'm just trying to figure the math and what motor to use.
Mike,it might be and
intermitent duty motor.I need to check into that.
Offline D._Frederick
« Reply #27 on: September 02, 2005, 11:46:52 pm »
Rod,
With a band mill using a 1 1/4 inch blade, does not require that much force to feed the blade into the cut. My permanet magnet motor is 1/4 hp and it is moving about 300+ lbs,  it has plenty power for sawing. A bigger motor would speed up the jig back.
If you plan on using a board drag-back, then I would look for a system with at least 1 hp
Offline Rod
« Reply #28 on: September 03, 2005, 03:01:28 pm »
Thanks D._Frederick,I'm not planing on a drag back.
« Reply #29 on: September 03, 2005, 06:58:24 pm »
Rod,
Six rpm is way to slow for a carriage feed, it would require you to use jack shafts to get the rpm high enough. My gearmotor is 90 rpm and with a 3 1/2 inch capstant it gives me a maximum carriage speed of about 80 ft per min. I am using a 90 volt inverter which requires 120 volts ac.
Offline Rod
« Reply #30 on: September 05, 2005, 08:25:32 pm »
thanks D,I was wondering wat rpm to get.80 fpm seems kind of to fast to me tho.
Offline Rod
« Reply #31 on: September 05, 2005, 08:45:48 pm »
I''ll call Baldor tomorrow and see what motor I should use.
Saw Anywhere!
