Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Those of you with Alaskan Mills  (Read 2387 times)
Offline twoodward15
  • turnersville NJ
« on: August 09, 2005, 08:40:21 am »
I'm just wondering how you like them and wondering if there is anything you would change.  I have full access to a machine shop and am going to start building one.  It doesn't look too complicated and I think I could turn one out that will work well.  Does anyone use the Granberg chain?  Is it worth buying or would you recommend another brand?  Anyone see anything wrong with making it instead of just buying one?
108 ARW   NKAWTG...N      Jersey Thunder
Offline woodbeard
  • Sailors have sea legs, sawyers have board feet.
    • Dismal Guitars
Re: Those of you with Alaskan Mills
« Reply #1 on: August 09, 2005, 12:42:04 pm »
There isn't much to them, I built my own, too. I used some aluminum extruded tube, cause that's what I had. The edges are round, which I would avoid if I did it again, it tends to ride up over the sawdust, where a square edge would push it away.
Offline twoodward15
  • turnersville NJ
« Reply #2 on: August 09, 2005, 01:26:19 pm »
Oddly enough I'm using the square aluminum tube.  I was thinking the same thing you were.  My thousand dollar question is,  When you made the "t's"  that adjust the thickness of lumber you cut, did you justweld then flat or did you turn the the long tube 45 degrees and weld it to the piece that clamps to the bar?  Did you use "u" bolts and do they tension it enough?
Offline IndyIan
  • Weekend Woodsman.
« Reply #3 on: August 09, 2005, 02:56:06 pm »
I find the biggest time waster is setting up the guide on the log for the initial two cuts.  Do some research on getting a good set up for that and you'll enjoy sawing more.  I've used the 2x10 attached with wedges and screws method and its a bit painful to setup.
As for the mill it would be nice to have the depth adjustments not need a scrench, the u bolts are a bit mickey mouse but they work and are cheap to replace.
Good luck with it,
Offline twoodward15
  • turnersville NJ
« Reply #4 on: August 09, 2005, 04:22:52 pm »
Ok, I've got almost everything laid out now.  Tomorrow I will bring my saw in and make the clamps that clamp the bar.  I'll get it welded up and machine some channels for t-bolts to adjust for bar length and I should be good to go.  I used 1 by 1.5 inch square aluminum tubing for the main carriage and am using 1X1 box for the depth adjustment.  Woodbeard, do you know what size angle iron used for the cross braces?  I am using 2 by 2 angle but wonder if I should be using 3X3 to put the stainless rod (running at the top in the middle, for adjustment and a handle to push on I guess) in a higher position.  Any suggestions?  I'll try to post pics with my sally McCulloch on it.  Sorry that's all I have for now until I make sur eit works, then I'll upgrade to a real saw.
Offline DonE911
  • givme a minute, I'll think of something
« Reply #5 on: August 09, 2005, 08:44:17 pm »
As for the chain itself... I use the ripping chain from baileys, its pretty good stuff and cost effective... I get it in 25 ft rolls at a time.
Offline woodbeard
    • Dismal Guitars
« Reply #6 on: August 09, 2005, 11:20:35 pm »
Twoodward, I have very limited metalworking skills, so I actually used wood for the cross pieces, notched to fit the aluminum tubes. 3/4" allthread runs thru them with nuts on either side to adjust height, and the bar is bolted to the ends of the allthread. I wish I could help you out, but I think you're already building it better than mine. :D Mine is a real pain to adjust.
Offline D Martin
  • Work is always interfearing with my playtime
« Reply #7 on: August 10, 2005, 04:18:10 am »
A real improvement on an alaskin is a track and caraige like a bandmill. the caraige and track need not be all that heavy duty, the log bed does. My solution,    already made stuff. like a frankinmill   perry staging for the caraige, (free), track  -electrial unistrut 2 20 foot pieces 80$, chain link fence gate wheels 4 @ 20$ biggest cost 2 10 foot conveyor sections 60$ each. Not having to kneel down ,kill your back and breath two stroke gas fumes ...     priceless.
Offline woodbeard
    • Dismal Guitars
« Reply #8 on: August 10, 2005, 07:05:05 am »
For chain, I just use a good quality chisel tooth, full comp, and file it to 0 deg across the top plate.  I have tried modifying it like granbergs, but didn't notice enough if any difference to do it again.
Offline twoodward15
  • turnersville NJ
« Reply #9 on: August 10, 2005, 08:07:10 am »
Woodbeard.  What is full comp?  Are you saying that you don't remove any of the teeth or the tops of them?
Offline woodbeard
    • Dismal Guitars
« Reply #10 on: August 10, 2005, 01:23:21 pm »
Right. Full comp, or full compliment just means the standard cutter sequence, as opposed to full skip, or semi-skip. You will probably get several different opinions on what setup is best, so don't rely solely on my info. :D I settled on mine because it is simple and easy to make from readily available chain. It is also what Will Mallof describes in his classic book, "Chainsaw Lumbermaking"
Offline DonE911
« Reply #11 on: August 10, 2005, 01:34:07 pm »
You'll find an angle you like.  The ripping chain I get comes at 10 deg.... I have changed that for different woods to pick up a little speed....  the 0 deg doesn't work as well for me as say 5 deg on a hard wood like oak, but anything from 0 deg to 10 deg seems to work the same in softwood.
I don't have an alaskan, I have a logosol m7, but the cutting is the same.
Offline t_andersen
D Martin, any photos?
« Reply #12 on: August 10, 2005, 02:40:34 pm »
D Martin, is there any chance that you could post a few photos? Thanks
Offline fencerowphil (Phil L.)
  • LIKE CUTTIN' LONG! 30FT!
« Reply #13 on: August 10, 2005, 11:33:08 pm »
If you check out Will Malloff's book, Chainsaw Lumber Making - Taunton Press,  you will notice something very useful: :P
He rigged the mill frame and the saw in such a way as to let him change the chain with the mill still on the bar and the bar still on the saw.   Believe me -  filing chain can make you go into sawdust withdrawal pretty quick.  With this trick he said he could take a few sharp chains and keep his time into his cutting, not filing.  Since you are building your own mill, you could incorporate that feature from the start.
I have noticed what DonE mentions in relation to 0-degree ripping cutter grind:   This past Saturday I cut some 20-22" Pecan which had been down a couple of months (not good).   Since my bar is just a little sloppy, when I would hit those silica-hardened pockets in the Pecan, then chain would veer up just a bit.  Once it jacked the frame up off the log, there was no return.   The cutters would not bite enough to get back down, so the rivet heads were probably rubbing.
Pecan is the only thing I have cut that is tougher that Hickory.
On the other hand, there is simplicity.  Like Woodbeard I make my own chain from full chisel 404 full complement.  (I got a good deal on a roll of Stihl brand cheap a couple of years ago.)  It's just easy to grind the teeth off straight across and go with it.
BUT, LORDY, LORDY, NOT ON PECAN! smiley_whip
I finally took a 5/32 file and bevelled the insides of the cutter sides to help.   Once I close my rails and machine true I think I'll be ready for the hard stuff again.   (Not that kind of hard stuff!) :D
Amazin' how critical bar groove width and rail eveness becomes when yooz rippin! 8)
Phil L.
Bi-VacAtional:  Piano tuner and sawyer.  (Use one to take a vacation from the other.) Have two Stihl 090s, one Stihl 075, Echo CS8000, Echo 346,  two Homely-ite 27AVs, Peterson 10" Swingblade Winch Production Frame, 36" and 54"Alaskan mills, and a sore back.
Offline DanG
« Reply #14 on: August 10, 2005, 11:46:23 pm »
Hey Phil L.  Good to see you back on here. What's been happnin'?
Offline Brucer
  • The Kootenay Sawyer
« Reply #15 on: August 11, 2005, 01:51:56 am »
I bought Malloff's book when it was first published in 1982. Followed all his suggestions (including the one to try to improve on his suggestions ;D). I started off with the Granberg style ripping chain (because I had a couple of loops), but then I tried using his 0 degree design and found that it cut much faster and stayed sharp longer. Note that he also filed his gullets deeper.
Once I figured out how saw chain was supposed to work, I decided that a 5 or 10 degree angle full comp chain (Oregon makes one) would probably work better. I never got to try that theory out because I ended up converting to bandmills instead  ;D.
I drilled the bar out as Malloff suggested and that really made it easy to swap chains. However, I didn't take him too seriously about the air-hardening nature of chain saw bars when I drilled my first hole. Two expensive drill bits & 3 mini grinding stones later I got that first hole complete >:(. Then I took his advice and used a piece of half inch steel plate beneath the bar when I drilled the second hole. I drilled slowly with plenty of cutting fluid and the second hole went in like a dream. I only bothered to drill a single half-inch hole at each end of the bar.
Bruce    LT40HDG28 bandsaw with two 6' extensions, ED22 twin blade edger.
Offline D Martin
« Reply #16 on: August 11, 2005, 04:18:01 am »
T I posting a pick here is harder than I thougt it would be, I did manage to get a pic in my gallery , click on members gallery its the only pic i got in there there are som companies that sell their design. procut comes to mind. I enjoyed designing my own and as alot of the parts I used were already built things, just modified to work for my application. It works well but as everyone says you moove up to bigger toys eventually. ie bandmills. It was fun to build though. Its for sale ifin ya interested
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #17 on: August 11, 2005, 06:19:11 am »
here you go:
(for reference, click on "copy phot insertion code" then come back to a message and do a Ctrl-v to paste it in)
lots of dull bands and chains
Offline D Martin
« Reply #18 on: August 11, 2005, 05:44:46 pm »
Thanx dan, I musta spent 2 hrs trying to figure that out. Now if i could take better pics
Offline Dan_Shade
« Reply #19 on: August 11, 2005, 05:59:28 pm »
i think photography is a "knack", some people are good at it, some people aren't, and then there are those in the middle.
the secret to a good picture is sizing up what's important, I guess that can be learned, but anyways, that's a good idea, it always makes me happy when somebody figured something out to make life easier :)
Saw Anywhere!
