Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: circle mill power ? sawdust blower ? with pictures !  (Read 2313 times)
Offline UNCLEBUCK
  • Life out on the prairie !
« on: August 05, 2005, 09:30:33 pm »
Hey there , I had to make a cradle for my 671 detroit out of 12 inch channel steel and am wondering if I can go ahead and hook it up now and be done or do I have to pour a cement pad underneath it and then anchor the cradle to the slab , my blade is 48 inch . Will there be alot of torque to possibly make the cradle move ?  And I found a sawdust blower that says Buffalo on the side of it and am wondering if I can use it to remove sawdust from the pit ? My open flight elevator invention was a disaster . Thanks
Offline woodbowl
  • Making old fashion, oblong dough bowls, sure is a lot of fun
Re: circle mill power ? sawdust blower ? with pictures !
« Reply #1 on: August 05, 2005, 09:40:23 pm »
Hey UB, I don't know about the cement part but what about a drag chain to pull all that sawdust? That drag chain will make a mountain for as far as the chain will reach.
Full time custom sawing at the customers site since 1995.  Added homemade hydraulics to a 1988 manual WoodMizer LT40.
Offline J_T
  • Some of anything beats all of nothing Even in Dukedom Tn
« Reply #2 on: August 05, 2005, 09:43:25 pm »
I didn't put concret under mine wish every day I had  :-[  Nice blower  8) And while i'm here happy B day too 8) 8) May your saw awalys stay sharp 8) 8)
Jim Holloway
Offline UNCLEBUCK
« Reply #3 on: August 05, 2005, 09:49:18 pm »
 I just torched off the old drag chain gear box last week to slide the open flight elevator in and I mean I torched every little cling on that was hangin in my way and I was thinking if this blower could work it would be great or else just get a 2 horse dust collector from Grizzly or something ?  Thanks J_T , It will only take a few days to do the concrete thing and not much cost . I gotta go reload more b-day cake !  Woodbowl I am re-thinking that drag chain thing .
Offline J_T
« Reply #4 on: August 05, 2005, 10:16:52 pm »
Unclebuck if I had a motor handy I think I'd try that blower out . 8) In one of Buzz's photos is part of a blower system it's blower is outside and pulls the dust a long way . Another buddy of mine has his sitting next to his mill and blowes his dust down a pipe and it works great but has some smaller dust sturring in the air. If he had close neighbors he would have a bad day for sure though :D :D
Jim Holloway
Offline Bro. Noble
« Reply #5 on: August 05, 2005, 10:25:33 pm »
We use a blower about like that on our scragg mill.  We belt it to a shaft on the mill and use sewer pipe to run a suction line below the blades and a discharge line probably 50 or 60 reet away from the mill.  Occasionally we load the resulting sawdust pile into a manure spreader and spread the dust on the pasture.
Offline Ron Wenrich
« Reply #6 on: August 06, 2005, 05:49:30 am »
The blower will work.  We use one that's bigger than that, but we are blowing into a trailer.  I always liked drags.  Low tech and never wear out.  I alwyas made them with old corn picker chain and paddles.
As for pouring concrete, we never had concrete under the motor.  But, you do need a way to keep your belts tight.  We always drove something in the ground, like an old shaft, then put wedges behind it to keep good belt tension.  If you have slipping belts, you will have big headaches.
We do have concrete under our current motor, but it is a gen set and is not a direct drive to the belts, so there isn't as much pull on it.  We also have I beam sunk in the concrete for support.  If need be, we can tack it down.  I don't think that is necessary to your operation.
Offline D._Frederick
« Reply #7 on: August 06, 2005, 10:55:28 am »
Uncle-,
For your 671, I would get some used rail ties and set the engine on them. Put a couple of dead men in the ground and use turn-buckles to keep your belts tight.
We had a chain drag system on the American mill. There was a pit under the saw and with sheet metal to direct the saw dust to the chain. The only problem was that you needed to take links out of the chain for wear.
Offline woodhaven
  • Circular Saw Diehard
« Reply #8 on: August 06, 2005, 04:33:30 pm »
UNCLEBUCK
 Don't worry about the belts just get the engine so it won't move. The belts are easy to fix.
Richard
Offline UNCLEBUCK
« Reply #9 on: August 06, 2005, 08:23:34 pm »
Thanks for lookin and thinkin about this everybody . There is no belts , its going to be direct from the transmission to the arbor and I have a shear collar in between . I guess I should have said that yesterday . I got so many questions going into the unknown here doing this but all your input is very much appreciated because then I know what to do the next day and whats good and bad . I been a welding alot now hooking up stuff I torched off when I pulled the motor out. I have the right rotation off the transmission to match the blade but I have to fire it up tomorrow and put my handheld tach on the back of the tranny and see what kind of rpm I can get in 4th gear . I dont have a clue but am hoping I can get up atleast to 400 rpm , blades hammered for 475 so I will cross my fingers .
Offline UNCLEBUCK
« Reply #10 on: August 06, 2005, 08:32:56 pm »
I have decided to pour a cement pad underneath but have to wait until I see how many rpm I get ,then I will know if I can eliminate the silage chopper gearbox and just hook to the tranny . Its getting very confusing but I hope it turns out ok, its one of those projects that I have waited a long time to do and now I know why . Also this motor has a Vickers Vane hydraulic pump and a air compressor and am thinking about not using hydraulics and go back to the belt drive for the carriage . All I have to do to convert from a hydraulic carriage back to belts is just unhook the chain at the hydraulic motor . I am beat tonight but tomorrow I will know. Thanks to all of you ok !
Offline UNCLEBUCK
« Reply #11 on: August 06, 2005, 08:40:29 pm »
Also when I went wild with the torch a few days ago I torched down the spot where I stand and pull the levers behind my bullet proof shield and now the hydraulic levers are hanging in the air and I think I can get about 3 feet closer to the sawblade and make a better and wider area for the boardman to slide cants back across to the sawyer . Before I was kind of shy of the blade but after getting some experience I am not afraid of things as much .
Offline UNCLEBUCK
« Reply #12 on: August 06, 2005, 09:04:23 pm »
I hooked a 1750 rpm motor to this blower and just a nice breeze came out. I suppose I have to get a 3450 rpm motor to make it work ?  I would like to power the sawdust blower off of this detroit motor some place if my brain dont have a meltdown trying to figure out v-belt pulley sizes etc..   ???
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
« Reply #13 on: August 06, 2005, 09:14:05 pm »
  Uncle Buck, our Blower sat IN the pit, and had a large V pulley on the mandrel down to a smaller one on the Blower. There was a shaft running under the Husk to the Blower.
  I would also consider getting that exhaust pointed up into the air. The roar will deafen you. The higher the better, 8' or so.  I had a coarse screen at the intake, to keep chunks from being inhaled.
  So far, lookin good.   ;) ;) ;D
Online Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #14 on: August 06, 2005, 09:21:44 pm »
I like it 8) 8)  Why didn't your elevator idea work ???  I've got a 7" wide grain elevator under the Corley.  It works great and has for over 30 years :)
Offline UNCLEBUCK
« Reply #15 on: August 06, 2005, 09:30:18 pm »
Hey Harold now that is a idea I think I will try ! I got a 3 foot pit below the blade and its boxed in with treated 2x6 t&g and this blower would drop down in no problem .  Do they make a big diameter v-pulley like in 2 pieces because I have now way of ever getting the saw collar off but this idea is do-able and thanks a whole bunch  ???  Corley I always am alone and I had everything all done with the open flight 45 foot very nice kewanee elevator and I wanted to shove it 6 inches farther in with the front of the backhoe , well I went 6 inches and went in and looked and I crushed the area where the elevator pivots.Just like a spam can   :o. It was so hot the day shoved it in and I couldnt see out my glasses very good from sweatin so hard . I should have cleaned me glasses  :D
Offline woodhaven
« Reply #16 on: August 06, 2005, 10:34:45 pm »
UNCLEBUCK
Nice looking setup you have there. I am still using gas and don,t have anywhere near the torque you will have with that 671. I am glad to see there are still some more of us circle mills out there. I run a 52" blade and burn gas. It  cost a fotune. I wish I had a deisel
Richard
« Reply #17 on: August 06, 2005, 10:38:56 pm »
 UB, I know there are 2 piece flat pulleys. Have no idea about V pulleys ???
  You would slide a 1 piece on from the end opposite the saw collar. The one I had, had a bracket with the shaft going to the fan. Can't remember the brand. OAS don'tcha know ???
Offline J_T
« Reply #18 on: August 06, 2005, 11:00:30 pm »
Unclebuck when I  took the motor off that 510 M F combine it had a hyd. pump on so I just went on and used it It power a turner a push log deck and the carrage too. I think I have saw split v pulleys but don't rember where may of beem MSC or Mac Mastercarr ??? ???
Jim Holloway
Offline WH_Conley
    • Stone Hill Hardwoods
« Reply #19 on: August 06, 2005, 11:02:38 pm »
If this is the same motor out of the picker we were talking about a few month ago you should have several hydraulic motors, valves and at a couple of pumps. Maybe hook a motor to to the blower?
Bill
Saw Anywhere!
