Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: tires as bandwheels  (Read 1341 times)
Offline DragonsBane
tires as bandwheels
« on: August 02, 2005, 06:03:45 pm »
 is there a way to shape the tires to get a crown? maybe mount a grinder on a shaft to get them shaped? the reason I ask is if it is possible to shape the tire then a larger tire could be used thus relieving some of the fatigue on the bandblades.
"But when a long train of abuses and usurpations, pursuing invariably the same Object envinces a design to reduce them under absolute Despotism, it is their right, it is their duty, to throw off such Government, and to provide new Guards for their future security."
De Opresso Liber.
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
Re: tires as bandwheels
« Reply #1 on: August 02, 2005, 06:22:37 pm »
 Tires will crown when ya air 'em up. We used NEW taars. If we were to do it again, we wood use used taars. The high tread works well on a 1¼" blade, but, wood not work very well on a 2" blade. SOME taar stores will peel the tread for ya.
Offline Rod
« Reply #2 on: August 02, 2005, 06:49:11 pm »
Flas,so are you saying that these blades wont work on tires?
http://www.toolcenter.com/Lenox/woodct.html
I was just about ready to get me one of  those 2 x .042 (.072)
« Reply #3 on: August 02, 2005, 08:02:54 pm »
  Never said that.  ::)  With taars, any soap or oil will make the rubber slick and then sticky. Buildup on the blade will be terrible.
  Get used taars, even if there is nearly canvas showing.The rubber on the outside is for road wear. It does little for strength. The CANVAS is the strong part of the taar.
  I can show you a homemade mill, that runs a 5" or 6" blade. He used 8 lug hole wheels and taars. Canvas is showing. He has run nearly a million ft of lumber through this mill. Never had a taar problem. He can use a little soap, as the Heart Pine down here is VERY sappy.
  I try to post what we have learned, doing things differently. D. Frederick talks about vibration. We DO have a little vibration. I adjust the engine speed a little, and the vibration goes away. One tire (idle) has a slight mis alignment. Does NOT matter. The Blade runs true.
  WM uses a LOOSE belt on the band wheels. Don't tell me these do not cause vibration. It is supposed to shake the sawdust out of the grooved V pulleys.
  I wood not have any problem using taars with a 2" blade. Put 60 PSI in 'em.   WHY do you justify the 2" blade ??  Maybe I can learn sumpin.  ??? ;) ;D
Offline Buzz-sawyer
  • To see it is to saw it....
« Reply #4 on: August 02, 2005, 08:16:47 pm »
Deadhead
Are you sayin the worn tires will give a wider crown area for a wider blade?
Also do yo recon no adjustment is really necissary for camber on the idler side?
    HEAR THAT BLADE SING!
Offline Rod
« Reply #5 on: August 02, 2005, 08:48:07 pm »
well Deadheader,they told me to run the blade tell it was wore out then just throw it away.I was thinking that I wouldn't have to change the blades as often and I'd save on sharpening.The blade for my mill 12' cost $132 .I just was thinking that carbide is worth the cost,but i don't know for sure.Also I don't cut any trees that have metal in them.A 2''x12' blade is about $40.I've never use a 2'' blade but I was thinking that I would be able to cut alot faster with it also.So wath do you think?
Offline DragonsBane
« Reply #6 on: August 02, 2005, 08:50:35 pm »
 Good deal. I gots a plenty used taars 'roun hare. Just gotsa pick a couple or three. Now mabee I needs ta get fabrikatin.
De Opresso Liber.
Offline Rod
« Reply #7 on: August 02, 2005, 08:51:10 pm »
Oh,any another thing.The trees here dont have any sap that builds up on the blade.
« Reply #8 on: August 02, 2005, 09:24:41 pm »
Rod,
I would think twice about that much money for a blade. Will the back hold up long enough to make the extra expense worth it?    Blades will break regardless of the configuration of the tooth.  It's the back that is holding the whole thing together.
I think you need to shop around for some better blade prices too.  You should be able to do much better than what you list.
The width of the blade is dependent on the size of your guides as well as the width of bandwheel, assuming you were using standard wheels.    You may get away with using a 1 1/2 inch blades with a 1 1/4 setup but you won't get away with a 2 inch blade on a 1 1/4 setup.
Offline Rod
« Reply #9 on: August 02, 2005, 09:34:08 pm »
Tom,I haven't really sit down and crunched the numbers.I might need to do that.But they say the bade will last 6 time longer then the other blades.
So does anyone know if you can cut faste witha 2'' blade?
Offline Rod
« Reply #10 on: August 02, 2005, 09:37:21 pm »
Tom,I have car tires for wheels and the guide are just some car bearing.I can use washers if I need to make the giudes wider.
« Reply #11 on: August 02, 2005, 10:25:06 pm »
  Buzz, Taars will crown when aired up. Under strain from the blade, they May try to flatten a little. I haven't got a high speed camera to verify this. All I am saying is, they crown metal wheels so the blade runs in the middle, why not taars ??  If the taar flattens too much, the blade should crawl, ours does not.
  Camber needs to be done right, when you build the sawhead frame. We adjust the toe in-out with the extra bolt, when we tension the blade.
  Rod, We use 15'-8" blades, 1¼". $20.00 each. No Carbide. I spoke with 2 blade reps at Sawlex. They both stated, "If you de-bark, Carbide will last". I asked about grit, Silica and other gritty stuff. Carbide will dull, then you have to force it. Too rich for my blood. The guy with the 5"--6" blade, swages his, no side set. He tried to talk me into that, but, I don't agree with that with narrow blades.
 With a homemade mill, unless you are very skilled and can engineer to a high degree, a homemade mill will not give the production speed of a quality manufactured mill. We do very well, but, we did not spend a fortune, so, we can saw a little slower. Never ran a WM, so, the numbers Arky and others post, impress me. Also, we do a lot of big, very wet logs, so, we need a break along the way.
  When I saw, I can bog the 24 HP Honda, as well as anyone, so, how much faster can you go ???  3 belts, 50 HP, you can saw faster.  ::)
  No sap buildup, eh ??? What brand of trees ya got ?? I'd really like to know.
  Tom's post I agree with. Only thing I will add is, larger dia. = longer blade life. We don't tension quite as high as WM, so, we sharpen blades down to under 1" wide, till the gullets sing on the rollers, and the set is nearly knocked down by the roller guides.
  I built roller guides from bearings. They would get rusty from water running on the blade and shell out. Replaced them with Cook's roller guides, and we get excellent mileage from them. Overgreasing will cause bearing failure. Learned that from Bibbyman and Mark M.
  Building your own mill is a great feeling, especially if it works when yer done. Several FF members have seen our mill run. Noone gave the thumbs down. WE were fortunate to have the insight to study designs and ask questins. That's why I try to help others. ;D ;D
Offline Rod
« Reply #12 on: August 02, 2005, 10:39:25 pm »
Deadheader,I don't cut any grity wood,and the wood around here is just the stuff that grows here in West Virginia.So wil the 2'' blades cut fast.er tho?
« Reply #13 on: August 02, 2005, 10:55:32 pm »
  Rod, never get sand ground into the bark from felling or draggin?? What about mud ??  More HP will saw faster, no matter what size the Blade.
  Got Red Cedar ??  Got Ash ?? Got Pine of some sort ??
« Reply #14 on: August 02, 2005, 11:11:31 pm »
Rod,
The wider the blade, the more beam strength available so the more horses you can apply to it.
It's the Horsepower that gets you the speed.
The wider blade will be supported in the kerf better though and that will lead to a more stable blade and less waviness or following the grain.
It takes more horses to drive a longer or wider band too.   You have to overcome this before you will recognize any benefits.
Offline Rod
« Reply #15 on: August 02, 2005, 11:16:27 pm »
Tom,I have plenty of power.I'll like to be able to use all of it is the reason I wanter to go to a 2'' blade,and I really don't know how much it would cost to get a plain 2'' blade resharpened
FDH,I clean all my logs and i cut oaks,hemlocks, beech,poplar and a few other kinds.No cedar tho
OK,lets me crunch some numbers.say $20 for 1 1/2'' 7 plain blades wil cost $140
1 carbide blade cost $132
get the plane blades resharpened every1000 feet at the cost of $6x3 $18 x 7 =$126 + 7 blades $140 total=$226
So it looks like if I can get half the life of a plain blade($226) it would be worth it.I was think that with the wide blade you could feed faster.
So do you see anything wrong with my figurings?
Offline Furby
  • Blurb....
« Reply #16 on: August 03, 2005, 03:13:26 am »
Yup, sure do!
The first time you put on a new blade and start taking off teeth from hitting too much metal, you'll think otherwise on those carbides.
My 12' Munks in a box lot came to just under $15 each with shipping.
« Reply #17 on: August 03, 2005, 06:51:22 am »
 Noone is forcing you to give up, Rod. We are just giving you facts, from things that we have all experienced. Someday, you will hit metal. There is no way around that. Damage one blade and there goes production, until you can order in another. We have over 40 blades. Tom has hundreds. So has Arkansawyer and many others.  We have these for a reason.
  Buy that one carbide blade. It's ok with everyone here. Better get something for backup, when that one blade breaks.
  I did what I wanted, against some good advice, and got away with it. You might too. 1½" blades work very well. We have 2 of them and do not change the roller guide to accomodate them. They are used strictly for Heart Pine.
Offline Rod
« Reply #18 on: August 03, 2005, 07:30:14 am »
Deadheader,I might just try one those for a test run.I remember when carbide blades came out for  circular saws and all the other carpeneters thought I was nuts for buying a carbide blade.They would sharpen those plain circular saw blades and take them to the job sites with them and I'd just take my 1 caubide blade with me.I was cutting wood while they were changing blades,and then after work they'd go home and spend time resharping their dull blades.Now days I wont run a circular saw witout a carbide blade,I might be te same way on a bandmill,but maybe not too.I don't know yet.
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #19 on: August 03, 2005, 07:32:20 am »
if you can afford it, try it out, I wouldn't want to just have one band, though.  I know how I work, sawing off clamps and backstops and whatnot  :D
lots of dull bands and chains
Saw Anywhere!
