Recent
349 Guests, 1 User
Welcome to The 2024 Forestry Forum!
Do you have trees to grow? Logs to saw? A forest to manage? Chainsaws to fix? A sawmill to purchase or maintain? Timber related business to run? Lumber to dry? Trees or plants to identify? A cabin to build? Are you hungry and like FOOD?
Or would you just like to pull up a stump and visit with a friend?
If any of these and a multitude of other topics apply, then The Forestry Forum is the place for you.
What Will you Find on the Forestry Forum?
Pages: [1] 2 ... 40
I have an older LT 40 With the debarker only moves in one direction. The motor does not function in both directions. Thanks for taking time to answer this
2 Comments
I've been working on my 57 acres for years now, lol. I have been and am still most curious about clearing a tract for timber stand improvement (even aesthetics in my case) of mostly hardwood saplings that are 1/2 inch diameter and larger. Countless ones 1 inch to, say, 4 inches. (Or, I could limit it
Read More
5 Comments
Any suggestions on what the idle rpm and high rpm should be on a 24hp/3600rpm engine?
6 Comments
1st post here hopefully someone can help . I have no power to hydraulics on lt 40 super . I'm not very good with multimeter or electronics but the solenoid in small box next to battery has 12.8 on the left post , when I turn on key right post which has wire going to brass block that contacts the copper...
Read More
11 Comments
When is it desirable to use large branches as sawmill logs?
I had a large black cherry come down in the woodland this Winter and there are a few shorter yet clear branch sections...
(Seems that short pieces from branches can be marketed... Is tension still going to be an issue there?)
Read More
11 Comments
Pages: [1] 2 ... 40
