Peterson Portable Sawmills
Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Author Topic: Least expensive way to increase sawmill production  (Read 8624 times)
Offline Bibbyman
  • Pro-Sawyer Mary and Bibbyman
    • Warden Sawmill
« on: August 01, 2002, 12:10:29 pm »
You've got a mill that the manufacture says should produce 500 BF/day or 1,500 BF/day or even 10,000 BF per day but you can't seem to get half that.
It may be you're not getting all the power to the blade or maybe you've not got just the right set, face angle, etc. on our blade for the application.  Maybe you're not pushing your mill to its limit.  Could be a lot of things.
But once the mechanical things are ironed out, then its time to look at other aspects of the operation.  For sure layout and material handling can often be improved.  But then what? Is that all there is?
Well, you may be able to double your sawing rate just by making decisions faster.  You may not be aware of how long it takes you to position a log, get the opening face in your target,  make the decision to turn to a new face and so on.
Once you get to thinking about it,  maybe you're spending half or more of your time deciding what to do next instead of going ahead and doing it.  I know when I first got our mill,  I was meticulous in placing a log on the mill, getting just the right face to make my first cut, etc.  Six months later I went back to saw for my brother-in-law and after a couple of hours he made the comment that I was sawing twice as fast as I did the first time.  A lot of that was learning curve but some was just thinking about how much time I was investing in analyzing and making decisions.
Here are a few ways I've found to increase the BF/Hour rate:
First thing I did was throw away the tape measure.  I began to trust my eye to level a log and make the fist cut.  On a Wood-Mizer, you can use the tops of the backstops as a visual guide for leveling.   You can judge the opening face depth by eye also.  If not deep enough,  back out and bump it down 1/2" and go at it again.  If the correction only take a second why spend a minute to measure and calculate and still could be wrong 30% of the time?
Anticipate and decide your next move while you are sawing.  For example, say you've got the log your are sawing squared out and are sawing it "through and through",  you'll have plenty  of "mental" time to look at the log coming up next on the skidblocks.   When it hits the deck of the mill,  it should only take seconds for the sawdust to start flying.
With a perfect log, you should be able to position it any old way and it would make no difference to the outcome.  But I've yet to find the perfect log.  The classic method of log positioning is to review the log and look for sweep, knots, defects, cracks, etc. and then position the log accordingly to open the best face or the face with a major defect or the "hump up", etc.  But the way I figure it,  every log only has four faces 90 degrees from each other.  So in the step above,  I make a mental reference to the four faces.  When it hits the deck and backstops,  I only rotate it enough to get the next available face.  Unless there is some compelling reason, I saw any of the four faces first.  I figure you got to saw all of them anyway so why take time rotating the log?
I've seen a lot of sawyers from beginners to the hotdog factory demo guys and I'd say I'd rank about a 5 out of a scale from 1-10 sawing grade lumber. Mainly because I do take more time to grade the boards coming off and a lot of the logs we saw for grade have some major defects to deal with.  An error could change a $12 board into $4 board real quickly.  Three or four of them in a log and the extra few minutes are well spent.  But when sawing common farm lumber,  I speed up to maybe a 7 or an 8 on a good day.
The real trick to it is recognizing how much time your are spending making decisions then making a conscious effort to move that process forward while you are sawing so there is a minimum delay in execution of the next action.
Sawing since '94
Offline Geoff
  • Sawmill & woodlot operator in eastern Ontario
    • Loyalist Forest Products
Re: Least expensive way to increase sawmill produc
« Reply #1 on: August 01, 2002, 04:29:08 pm »
I'd agree with Mr. Bibbyman.  I went the equipment route by purchasing the forklift, live deck and edger, but as you-all know, it all comes down to the operator.  I liken it to doin' hay.  The fellow on the tractor sets the pace, and the baler spits out the bales to the wagon.  The folks on the wagon have NO CHOICE but build the load, otherwise there's a mess on their hands.
The sawmill needs a steady "push flow" to keep all the operators (even if you're working alone), to keep the numbers up.  My next project, taking the board return feature and designing a chute to guide the boards and slabs into a hopper for bundling or sorting.
Nothing beats a good operator and a sharp blade.
Geoff
PS.  Maybe I'm cheap, but we run a LT40 (non hydraulic), and regularily achieve good production numbers.  I am designing a power clamp that runs off a hydraulic pump on the edger.  It's on my "Honeydew" list beside the new bathroom.
Offline Frank_Pender
« Reply #2 on: August 02, 2002, 04:44:45 am »
Bibbyman, I like you analysis of time use.  It sort of reminds me of teaching 7th graders (12 @ 13 year olds)  for 30 years.  You hve to really get outside of the box when production and quality are concerned.  Always being a step or two ahead of the curve you are seeking is really what I have often called "value added" to what it is you are trying to accomplish.   You surely have given many of us a refresher course is the business of getting the job done well.  thank you for sharing.
Offline JoeyLowe
  • "In the German Tradition"
« Reply #3 on: August 02, 2002, 05:33:03 am »
Hey Bibbyman:
That's a good way of describing what plagues many an operator.  I offer my own limited experience here too.  Of course, the almighty learning curve will slow many a person down no matter their vocation.  After awhile though, the fidgiting for the right hydraulic handle to grab or remembering which switch moves the blade up or forward should go away, and then the sawyer can start to work on his production outputs.  Guess what I'm trying to say is "Sawyer, know thyself!" or more aptly put, learn your equipment if you plan to use it.
Afterwards, things such as which face of the log to open become very important.  My LT 40 Super has been advertised to produce as much as 6500/BF a day.  Now, I have never hit that mark, bu then my blade isn't in the wood all day either.  Too many other things going on.  I've hit 3200/BF in a single day, and a job we start next week will require us to consistantly produce 3000/BF a day to stay on schedule.  Now that I have a trained, dependable crew, that goal is attainable to us, but it took a lot of practice.
I have adopted Bibbyman's suggestions about not depending on the tape measure and that alone has significantly increased my production without sacrificing quality.  Unfortunately, I know of one sawyer who will spend 20 minutes leveling a log, make his cut and then spend another 20 minutes taking thickness measurements along the face of the lumber to insure that his lumber is accurate.  He cuts an average of 300-500/BF a day on his Woodmizer LT40 Super.  To each his own!
Joey Lowe
"Working towards perfection has to be a part of anything one does.  You've got to put yourself into it." ... Sam Maloof (chairmaker)
Offline woodman
  • I love cutting lumber on my wood mizer
    • Jim Cripanuk's Portable Saw Mill
« Reply #4 on: August 02, 2002, 07:50:45 pm »
 On the WM tape thay say K.S.I.W.  keep saw in wood if you do watch board feet go way up if the blade is not cutting your not working
                                  K.S.I.W.
  tape this to your saw and doit all day
Jim Cripanuk
Offline ElectricAl
  • 1993 LT40HDE15
« Reply #5 on: August 02, 2002, 08:18:25 pm »
We used to use the tape measure trick when we were portable. But it was time consuming and not to accurate.
When we went stationary, and started to saw for grade for the green open market, we had to pick up the pace.
The first thing we did was add 2 heavy duty batteries. They sat under the hydraulic pump, and powered the pump regardless of the head position. The batteries were charged by a battery charger on a timer. This allowed a helper to load the next log. But the big speed was turning the log. When I broke out of the cut, the helper could release the clamp and start the turn as I pushed the flitch off to the bed rails. If the log or cant hangs up on the log stops I'm right there with a cant hook to help. On small stuff, the clamp can be moved back and I can back turn by hand faster the the turner can go.
Also, I can raise the head while the log is being positioned. Another big time saver.
The second thing we came up with was eliminating the tape trick ( not a good trick ). While the blade is not moving and as I am coming back ( we do all log movement with the saw head at the tail end ) I pick the low spot in the log and lower the blade until it touches the bark. At this point I raise slightly and continue the return back. With the number from the low spot I subtract 1" or 1 1/4" depending on the bark thickness and make the cut.
The goal is a 4-6" opening face board.
We also Full Taper saw. This gives you full length opening lumber. The highest valued lumber is on the outside. Full Taper sawing takes the taper out in the center of the log which is of lower quality. When sawing high value logs like Cherry there is a big price differance between Select/Better and  1 common. At one time the price difference between S&B and 1C was $1.20!!!  So the little extra time to Full Taper saw paid off with big benefits.
ElectricAl
Linda and I custom saw NHLA Grade Lumber, do retail sales, and provide Kiln Services full time.
Offline Ron Wenrich
  • Forester
« Reply #6 on: August 03, 2002, 03:34:52 am »
Here's what I have found to be productive on the circle end of things.  I do primarily grade sawing.
Limit carriage movement.  That would translate to head movement for you bandmillers.  I've seen a lot of guys who will run their carriage pretty far beyond the saw after the cut has been made.  They also run their carriage pretty far back when it isn't really necessary.
Multi-task whenever possible.  I will be pulling my headblocks back and downturning on the return.  Also setting my vertical edger on the return.
Don't become overly dependent on laser lights.  They are a good guideline, but you can go nuts with precision.
Saw thicker lumber.  My production goes up when I can add 5/4, 6/4, or heavier to the mix.  Fewer cuts, more production, and quite often better grade yield.
Saw longer logs.  Cutting one 16' log is the same as cutting two 8' logs.  Half the turns on the log.
Get rid of logs that are too small and too large for your mill.  Why cut logs that aren't profitable?  There is a breakeven point.  As a miller, you should know where that is.  It varies by length, grade and species of logs.  Find another market for those type of logs.
Get rid of crooked logs.  There isn't that much grade in a crooked log.  It takes too long to get them load and position.  They are hard to turn and they bust up equipment.  I've noticed they take more time to load and turn then they do to saw.  Production costs go up.
Saw for the biggest piece of blocking you can get.  Ties pay more than pallet stock.  Pallet blocking quite often pays more than 2 Common when handling and down boards are considered into the mix.  I've had bridge timbers that paid more than F1F red oak, when you consider your loss of yield into the mix.
My best production days are sawing long tulip poplar with multiple thickness.  It is a lot more interesting to saw than straight 4/4.  My worst days have been sawing fence post locust.
Offline ARKANSAWYER
  • Poor white Southern trash
« Reply #7 on: August 03, 2002, 04:55:35 am »
  If your are not making saw dust you are not making money!  I pay my help a percentage of what is sawn for the day.  After my kids learned that they could make $20 more a day just by doing things that kept the saw head moving production went way up.  All I had to do was saw.  We hit several 3000 bdft 8 hr days and that is good with a LT40HDG25.  But for a good day you have to look at your set up or you will be quickly covered up in piles.
  I guess Mary is getting more coffee in the mornings to get her up to speed :D
ARKANSAYWER
ARKANSAWYER
Offline Bro. Noble
« Reply #8 on: August 03, 2002, 06:36:44 am »
Ron mentioned limiting head movement on bandsaws.  I've seen people saw through the log, raise the head to clear the board, return and then have the board pulled.
When making a cut, if you stop before the blade completely exits the log(but the cut is complete) then give the board a shove over the blade.  The offbearer pulls the board while the head is returned.  Saves a bunch of time if working with two people.
Noble
« Reply #9 on: August 03, 2002, 08:10:00 am »
That works on a mill where the blade has been stopped, like an older WM but I've found that it's faster and safer to have the off-bearer (I call them off-loaders) at the end of the mill where the blade enters the log.  A good off-loader will have the board moved almost before you can get the head of the mill stopped and it keeps him away from the blade too.
It allows him to make the decision as to putting the board in the loader for trimming later or stacking it.(if you trim on the mill. He will shortly learn to bounce the board to the loader.
One thing I try to emphasize to fledgling off-loaders is to keep the slab pile neat and the board piles straight.  Don't put piles where you have to walk with the board, or at least as close as you can.
 Leave an open work area.  Move slab piles and board stacks frequently to get them out of the way of an industrious off-loader.
As a Sawyer, don't be afraid to take frequent breaks.  Off-bearing is difficult work and you can put one on the ground if you drive him too hard, especially in hot weather. If you find that you need a break then he probably needed one a long time ago. :)
I tell my customers, who provide the labor,  that if my saw stops, I'm working for free.  A little guilt helps when you can't always control the situation. :D They should realize that you are trying to make a buck as well as save them a few.  Helping to take a big slab or board off of the mill goes a long way in making the off-loader appreciate you, but you can't stop for every one because "your working for free" :D
My favorite layout
When working alone
« Reply #10 on: August 03, 2002, 08:49:50 am »
While I'm at it, I want to mention this.
When you buy your mill don't get one where you need to take a mechanic with you to the job.  Some are terribly maintenance dependent and break frequently.   Your job is to saw wood, not turn wrenches.
I think that some manufacturers think that a sawyer likes to tinker and because they like to turn wrenches, so will the sawyer.  Wrong!
My favorite sawmill manufacturer told me several years ago that their aim was to make their saw pretty much maintenance free for a year.  That is a tough goal but one that would really be appreciated by a sawyer and one that would save the manufacturer warranty efforts as well.
Look for sealed bearings in nasty places, Grease zerks conveniently located and parts that have been manufactured for easy repair rather than fancy units purchased by the maker for easy manufacture.  The easier he makes it on himself, fabrication wise, the more expensive and time consuming you can expect your repairs to be.
Time on the job is money, your custom sawing customers won't like it either, especially if they are paying for the labor.
Offline Ron Wenrich
  • Forester
« Reply #11 on: August 03, 2002, 11:07:10 am »
Seeing your diagram reminded me of an Amish mill where I did a little cutting.  He was running a Meadows handmill and had dead rolls to take the material away.
He was setting up skids to make the material seperation.  I asked him how he was setting it up.
Off the end of the dead rolls, he said he was going to stack the 4x6 cants.  About 15' beyond that, he had another set of skids.  He told me that is where we were going to stack the ties beyond the rolls.
What do you mean "we"?  I explained you don't carry ties.  They had been for several weeks and he worked with boys, not men.
We found a good setup where there was a minimal amount of moving heavy material.  They carried the boards a little farther, though.
Offline ElectricAl
  • 1993 LT40HDE15
« Reply #12 on: August 03, 2002, 11:37:51 am »
Tom brings up a good point about getting the flitch or board off smoothly and quickly. Linda has developed a method that "flicks" ( for lack of a word ) the board off and onto the bed rails. When I approach the last foot of the cut she has the board in her hands with a slight amount of side pressure. When the blade breaks out I continue about 4"-6" while raising the head slightly. Linda swings the board to the right some then pushes down and pulls back some. The board jumps right out of my way. Normally she can remove the board from the saw as fast as I return. Unless it's real wide then she stands back so the saw head won't hit her. I very seldom have to stop, only when a flitch hangs up on the bark. Break out, raise up, back up. Smooth and quick. Also, we do not stop the blade while backing up. This also saves lots of time. Think about it --- break out, stop forward motion, Disengage clutch, raise up, back up, stop, lower the head, engage the clutch, start sawing. By the time you have fiddled around with that clutch arm, I have cut half way through my next cut.
We spent 4 years clutching before going clutchless. It's a very hard habit to break not grabbing at the handle.
Did I hear someone say "your wasting Flex Life",  Well the increase in production per day off sets the little bit of lost flex life.
Try it and report back.
ElectricAL
Online Jeff
  • Lead Administrator
    • THEE Forestry Forum
« Reply #13 on: August 03, 2002, 11:57:51 am »
Al, In the few times that I have watched bandmills run, I have noticed that they stop the band once through the cut and engage it again only once they are ready to start the next cut. I noticed that immediatly. I never mentioned it, but it seemed like a big waste of motion.  I figure if I ever get one my band wont stop unless the logs run out. :)
The farther backward you can look, the farther forward you are likely to see. Winston Churchill.
Because inquiring minds want to know... ;D Expired Circle Sawyer-Automatic Commercial Mill-Since 1979
Offline Bro. Noble
« Reply #14 on: August 03, 2002, 01:03:33 pm »
I suggested to WM several years ago that a manual or video of different successful layouts would be very helpful to all of us, especially beginners.  We all have a little different set up depending on mill, labor, support equipment, and end product; but we could all pick up some good ideas from each other.
One factor in efficiency and safty is to keep things clean and uncluttered.
Another is not to try to go faster than you can perform the job well and safely.
I knew a headsawyer on a big circle mill who set the dog (he only used one) on the move , just before the log hit the saw.  He could do this really fast and hold a Bud at the same time.
You have to be willing to send a log over the saw once in a while operating this way ,however.  He had trouble keeping an edgdrman.
Noble
« Reply #15 on: August 03, 2002, 01:22:50 pm »
Wood Mizer taught me to run  my band only when cutting.  There were several reasons given, all of them valid at the time.  Band life was one of them. Not letting the band hit something on the way back was another. Nothing holds the band on in reverse.
It was also a means of returning the head of the mill without having to raise the head above the boards.  If you stop the band as the teeth exit the cant then you can return the head of the mill as you drag the blade back through the kerf you just cut.  It makes operation a lot faster because you can pull the first board as you cut the second one and the mill never stops.  Drag Backs, the fingers behind the blades today, have pretty much made that procedure obsolete on newer mills.
My shoulders have suffered tremendously from pulling the clutch handle.  If I knew then what I know today, I would not have operated the saw in that manner.  Torn Rotor cuffs and serious Tendonitis have led me to therapy and potential surgery.  Repetitive Injury is a common place ailment today which reflects our ignorance over the past years. Hopefully next generations will pay attention to things like this and sun exposure and proper lifting techniques, etc.  Good boots and protecting ones feet is a commonly ignored safety item. Youth doesn't last forever.
Folks that do manual labor tend to do things that, years later, they wish they hadn't.  They will lift heavy objects rather than wait for help or equipment, work without breaks, pride themselves in starting before dawn and finishing after dark, stack too high, not eat dinner (lunch), ignore associates, complain about another's slowness when it doesn't exist, etc.
"All work and no play makes jack a dull boy", I'm told. When we get older, we realize the things we've missed and the fellowship we could have had if we had just slowed down enough to smell the roses.  If I cut 2000 ft in a day at 20 cents a foot or 83 cents a minute,  what does a five minute break on the off hour and two 15 minute breaks a day cost, $41.50?  There are only four 5 minute breaks and two 15 minute breaks in a day if you eat dinner.
That's cheap insurance to make sure everybody comes back tomorrow and it doesn't come out of your 2000 ft day.
I try to remind myself, "who are you trying to impress?"
Want to add it back in?  Cut 210 more feet.
Offline CHARLIE
  • Don't wait 'til both feet are in hot water before you decide to put your best foot forward.
    • Coulee Region Woodturners
« Reply #16 on: August 03, 2002, 03:03:46 pm »
Tom says,
"As a Sawyer, don't be afraid to take frequent breaks.  Off-bearing is difficult work and you can put one on the ground if you drive him too hard, especially in hot weather. If you find that you need a break then he probably needed one a long time ago."
I say...." :-[ :'("
Charlie
Offline Bibbyman
    • Warden Sawmill
« Reply #17 on: August 03, 2002, 03:49:19 pm »
On our new WM Super with the 25hp 3ph motor and Accuset setworks,  we don’t stop the blade either.  But the return speed of the sawhead and the drop to new board thickness is much quicker than with the older mills we had.  On and 8’ log,  you’d probably spend more time stopping the blade,  return and then starting the blade again.  It may be a tradeoff of blade life vs. drive belt life, etc.
AutoClutch is a great option too!  Mary’s right arm was starting to look like Popeye’s after running the 96 Super for a couple of years.
Sawing since '94
Offline ARKANSAWYER
« Reply #18 on: August 04, 2002, 05:35:38 am »
  I throw the clutch lever up just as the blade clears the end of the log, bump up the head and start back.  Since I have to walk with mine I am there to push the slab/ flitching/board to the load arms.  Back up, drop to next cut start the head and pull the clutch lever, then walk around and get the slab and meet the saw head as the blade clears the log.  I saw alone most of the time and try to put in 1500 bdft days.  If you do not bump up on hickory you are going to lose a blade or two as the cant will bow up on you.
 As for those who work hard and have injuries they will live longer.  I see old loggers, cotton pickers, farm hands, ect all the time in their 90's and still getting around.  I know not of one banker over 70.  My Granny had sit around the last 15 years and her health was getting bad and she was falling apart.  At 82 she started pulling slabs and getting in the way around the mill.  She has worked several 12 hr days and in the heat in the high 90's.  Doc says she is getting in good shape and may live a few more years.  All will have some health problems and there are ways to prevent most but do not shy away from work.  Last summer this grandpa worked 3 teenage boys into the ground 4 days a week and then I came home and mowed the yard with a push mower.  I am for working smarter not harder but do not shy away from hard work.
ARKANSAWYER
ARKANSAWYER
« Reply #19 on: August 04, 2002, 07:22:10 am »
If you already heard this then........... :D :D :D :D :D
A newpaper reporter was in "the hills" to interview folks on their longivity because he had heard that "high landers" lived a long time. Finding an old fella rocking on the front porch of his mountain cabin he asked him what he attributed his longivity too.
"I don't know, never gave it much thought", said the highlander.  "I eat lots of salt cured pork, sweet tea, smoke a box of cigars a week, smoke a pipe in town, smoke cigarettes at work, dip snuff, chew tobacco and don't let a day go by without a quart of liquor".  I been chasing women all my life and don't sleep more'n about 2 maybe 3 hours a night.
"My God !, Just how old are you", asked the reporter".
"Be, nineteen next month".
I like it. :D
Saw Anywhere!
