JD
Egads you guys want to grow those too.
Their native range is the coastal fog belt from the very edge of the southern Oregon Coast to about 200 or 300kms south of San- Francisco on the California coast.
They will grow just about anywhere you plant them although they are not grown for timber production outside of their native range here. You need deep well drained soils and considerable moisture for them to grow well. They grow very fast... in fact a little too fast, it sounds like you may be in a good environment for them. They will grow an inch in diameter and 3 to 4 feet in hieght every year if well spaced. The limbs have a tendency to get quite large so pruning would be beneficial although pruning is generally not done here as well. They are very hard to kill in fact most regeneration is from sprouts off the stumps and root crown. They need lots of sun light to get established but will live nearly forever suppressed under a canopy.
The wood is used primarily for outdoor exposier such as decks, siding, fencing, shakes, hot tubs, patio furniture and the like. It is soft and has a tendancy to be brittle and also splits easily. The white sapwood will decay quickly but the red heartwood is very very rot and insect resistent. A downed old growth log will still be good hundreds of years after it hits the ground. It was used for structural framing in the region it grows because it is so common but other species are better for this.
