Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: 066 starting problems  (Read 826 times)
Offline J Beyer
  • If there were no trees, we would not be board.
« on: July 03, 2002, 09:38:34 am »
I bought a used 066 a couple of months ago  ;D  I love the power ;D  I finally got to use it a few weeks ago.  Sometimes I have a dickens of a time getting it going.  This is an older saw without decompression and sometimes it seems like I cannot pull it over fast enough?  I'm not a wuss when it comes to strength (I can lift around 100# block of wood) :o
I have yet to check the obvious like the sparkplug.  I did have the mixture screws check by an authorized Stihl service center.  Sometimes it idles down to low, so I may have to turn that up as well.
JB
"From my cold, dead, hands you dirty Liberals"
Offline Kevin
    • The Milling Masters
Re: 066 starting problems
« Reply #1 on: July 03, 2002, 10:03:12 am »
If you have a spark and fuel getting to the plug it should start.
Be sure the plug is grounded well when checking for a spark, you don`t want to damage the electronic ignition.
You can pull the air filter off and see if it starts better but make sure the area around the carb is clean and don`t run it or cut wood with the air cleaner off.
A new plug is a cheap investment.
Offline J Beyer
« Reply #2 on: July 03, 2002, 10:40:38 am »
I remember something a motorcycle/ATV mechanic told me once about sparkplugs.  A sparkplug can spark fine when out of the cylinder, but they can sometimes fail when put under compression in the cylinder.  Is this true?
JB
Offline Kevin
« Reply #3 on: July 03, 2002, 10:45:01 am »
I had a plug in a generator that would spark but wouldn`t fire.
The spark appered to jump across the plug and go to ground.
A new plug fixed the problem.
Offline Bro. Noble
« Reply #4 on: July 03, 2002, 11:02:09 am »
Jeff,
I used to have the same problem with an O66.  If it fired the first crank with the choke on, I could unchoke it and usually start the second crank.  Most of the time it didn't fire the first crank and would end up flooding (whether I unchoked it or not.)  I would either take the plug out and dry it or go to the truck and get the O44.
We always use the recommended way of holding the saw when starting-----holding the handle with your crotch(it took a lot of convincing to get me to believe this was safe much less safer!) and ours has a decompression valve.  For some reason I tried drop starting it once,  started right up.  Now it 's as easy starting as you could wish.  I just couldn't (or wouldn't) yank that thing hard enough with the handle in my crotch.
I'm still not sure the other way is safer.
Noble
Offline J Beyer
« Reply #5 on: July 03, 2002, 11:26:43 am »
Here's something that may be of help.  When starting I've had to crack the throttle open a little, even when warm.  I'll check the plug out Friday and get back to you guys.
Offline Kevin
« Reply #6 on: July 04, 2002, 05:00:42 am »
When I start my 066 cold using the choke the throttle is on full.
Offline woodmills1
  • the truth shall set you free
« Reply #7 on: July 04, 2002, 06:21:33 am »
my 066 is new, and I do think it is a bit tempermental about flooding, but it is still set to run a little rich due to breakin.  I drop start and found that the instant it kicks with choke on it wants to have the choke off, but still be on high idle.  One heck of a wood cutter the 066 is
James Mills    Lovely wife   collect old tools  vaccuming fool  36 bd ft per hour
 oak paper cutter,   apple jacks   ebonic yooper rapper nauga seller, Blue Ox? its not fast, 2 cat family,  LT70 and edger, 375 bd ft/hr, we like Bob, did I say free heat machine no oil 7 years
Offline Tillaway
  • Funny looking tall guy.
« Reply #8 on: July 05, 2002, 03:19:45 pm »
Quote
Yes... The ones with digital ignitions need 500 rpm to fire.  Without conpression release it can be tough.
Making Tillamook Bay safe for bait; one salmon at a time.
Offline keef661
  • sawdust &noise manufacturer
« Reply #9 on: June 27, 2003, 04:00:47 am »
same thing with the 066,found that it coughs 1st pull with choke on,got manual today supposed to put on 1/2 choke will try tomorrow
at present put on run&full throtle it starts with 2 ,3 pulls ,cold or hot superb saw
keef 8) 8) 8)
Keef
Saw Anywhere!
