Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Saw something new  (Read 1742 times)
Offline OneWithWood
  • showing the past to the future
    • RWT Biodiesel
Saw something new
« on: April 26, 2005, 02:27:19 pm »
While attending a tree and log grading class I witnessed two 'experienced' foresters bucking logs.  Both worked their saws (a Stihl and a husky for the record) like a bread knife as they were bucking the logs.  I had never seen anyone do this before.  Is there some advantage to doing this?
One With Wood
www.rwtbiodiesel.com
Offline etat
  • Member*
Re: Saw something new
« Reply #1 on: April 26, 2005, 02:49:40 pm »
I used to kinda do the same thing with the old homelite sometimes on bigger stuff.  Helps  keep the chips clear of the saw and blade?
Offline beenthere
  • EIEIO
« Reply #2 on: April 26, 2005, 04:00:00 pm »
Were the saws running at the time they were doing this.  ??? ;D ;D
Sounds like the joke I heard, where the punch line was something about "what's that noise?" when the saw was started.   ;D
Joking aside, I don't see any advantage in moving the running saw back and forth like a bread knife. I have seen people rock the saw as it cuts, which I interpreted to mean there was less wood being cut with the chain at any one time, and maybe a result of an underpowered saw so it did not bog down in the cut.
If the chain is sharp, I like to just let it fall straight down through the log. If the chain gets a bit dull, sometimes I will 'force' it a bit using the 'dogs' to grab hold and crank on it a bit (time to touch the chain up then).
But back and forth like a bread knife, not to my knowledge (experienced foresters are not necessarily experienced chain saw users  :) )
Offline jjmk98k
  • Crystal, My Shetland Sheepdog and forever soulmate, REST IN PEACE 7 May 2007
« Reply #3 on: April 26, 2005, 04:18:26 pm »
Hum,  I am a ROOKIE at all this, I just can't see any advantage to slicing the logs like that.... Seems against logic to me, let the saw do the cutting, it was designed for that!
But Like I said, i am a rookie...
maybe LOGGERS can gives us more advice?
Jim
Warminster PA, not quite hell, but it is a local phone call. SUPPORT THE TROOPS!
Offline tnlogger
« Reply #4 on: April 26, 2005, 07:14:49 pm »
 Wal now i've seen it done before. But it was one of dem city folks trying to cut fire wood  :D :D :D
gene
Offline OneWithWood
    • RWT Biodiesel
« Reply #5 on: April 26, 2005, 07:42:52 pm »
 :D :D :D :D :D :D
I love it!
I just did not want to say that to my teachers  ;D
One With Wood
Offline rahtreelimbs
  • Confirmed Chainsaw Addict!!!
« Reply #6 on: April 26, 2005, 09:14:17 pm »
Sounds like more work than is needed!!!
Nothing Like A  Modded Saw To Start Your Day!!![/SIZE]               Later, Rich.
Offline jjmk98k
« Reply #7 on: April 26, 2005, 09:23:24 pm »
I can see where some folks think "working the saw" makes them look more "Professional" and "more manly" you know, those who overexagerate motions......... grunts as he tightens something...
My co-worker is one of those type, would use a impact wrench to remove a tire valve stem cap if he could.
good grief!  ::)
Jim
Offline Kevin
    • The Milling Masters
« Reply #8 on: April 26, 2005, 09:45:31 pm »
Maybe they don't know what the dogs are for?
Probably expecting top bind.
Offline rebocardo
  • Atlanta GA
« Reply #9 on: April 30, 2005, 05:12:12 am »
Only time I "saw" with a powered saw is using a sawzall with a wood pruning blade to help clear out the shavings on something 6-8 inches wide that is green. Seems to cut better and faster and not sit in the cut.
I can see stopping/holding for a fraction in a cut to let wood chips or curls clear in big wood, especially when using full comp or when ripping. But, I cant see "sawing" doing anything even if the chain is dull, pressure would be better.
Then again, maybe they just wanted to see if you could say
"I see you saw with a saw" 10x fast  ;)
What would be scary is that the saw was kicking back and they were forcing it back into the kerf ...
Offline Ironwood
    • http://www.branchandburl.com
« Reply #10 on: April 30, 2005, 11:06:35 am »
  Perhaps they were doing it to get a smoother cut for end sealing??????????? I dunno but perhaps if'in they were veneer logs they wanted a smoother cut. I have tried to be very consistant when cutting high dollar logs as to get the endd very consistant.
                                         Reid
Offline maple flats
  • Life is what you make it!
« Reply #11 on: April 30, 2005, 01:31:31 pm »
sounds crazy to me!!
logging small time for years but just learning how, with a Forest stewardship plan, 2 compact Ford 4x4 tractors, 3point log arch, 8000# class excavator, lifts 2500# and sets logs on mill precisely where needed,  Peterson ATS upgraded to WPF mill, sugar maple/maple syrup a hobby gone amuck.
Offline twostroke_blood
  • I love the smell of Twostroke in the morning
« Reply #12 on: April 30, 2005, 05:25:03 pm »
Maybe they were bored  :D
Offline sawguy21
« Reply #13 on: May 01, 2005, 08:43:54 am »
What Jim said :D :D :D
Offline Timburr
  • Welsh border timber grower and miller.
« Reply #14 on: May 01, 2005, 03:58:35 pm »
No advantage at all. I think we all know where they are going....posers. :D ;D :D Could they saw like that all day and every day ??? The chainsaw is designed not to get tired.
Tim
Sense is not common
Offline D._Frederick
« Reply #15 on: May 01, 2005, 06:49:57 pm »
I would agree with Kevin, if the ground was uneven there blade could bind. By moving the saw in and out of the cut, the tip keeps enlarging the kurf so that the saw does not pinch. You don't see a guy here in the west that makes his living with a chain saw packing wedges and a sledge bucking large soft wood logs.
Offline Woodhog
« Reply #16 on: May 01, 2005, 07:07:14 pm »
I use that method to cut my logs now that gas has gone over 1.07 per litre..
I just keep the switch in the off position and move the bar back and forth..
Offline sawguy21
« Reply #17 on: May 01, 2005, 08:52:10 pm »
Woodhog, is that with the brake on or off? :D :D
Offline wiam
« Reply #18 on: May 01, 2005, 09:28:32 pm »
Only reason I can think of would be to agree with Kevin.
Will
Offline etat
  • Member*
« Reply #19 on: May 01, 2005, 09:58:05 pm »
I'm gonna say I ABSOLUTELY, POSITIVELY agree with Kevin. Especially since I've already admitted to moving the saw in and out of the cut in the past!  ;D
Saw Anywhere!
