Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Levelling big bits of wood.  (Read 4000 times)
Offline Ianab
« on: April 05, 2005, 02:43:45 am »
I've got some big slabs of wood dried now and need to basically level and true them up before making some furniture.
This is what I've come up with so far
It will hold the 2400w Makita router under the mill and move from side to side with the normal carriage adjustment. I've got a 2" dia flat router bit to mill the slab flat, by making 2" runs down the wood. A bit more bracing to keep the thing solid and some clamps to hold it in place and I'll be ready for a test run  :)
Weekend warrior, Peterson 8" WPF with Stihl 090 powerhead, Dolmar 7900 and Stihl MS310 saws and  the usual collection of power tools :)
Offline UrbanLogger
  • Don't trash that tree . . . TREECYCLE!
    • Midtown Logging and Lumber Co.
Re: Levelling big bits of wood.
« Reply #1 on: April 05, 2005, 09:33:30 am »
Ian, is your straight bit totally flat or are the "corners" rounded off a little?
I've found that I get a better surface with mine if they're rounded over.
It's not as big as your, but here's the cheapies that I use http://www.woodline.com/scripts/prodView.asp?idproduct=275
Scott Banbury, Urban logger since 2002--Custom Woodworker since 1990. Running a Woodmizer LT-30, a flock of Huskies and a herd of Toy 4x4s Midtown Logging and Lumber Company at www.scottbanbury.com
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #2 on: April 05, 2005, 11:21:49 am »
http://www.taunton.com/finewoodworking/pages/wvt095.asp
I'm planning on making one of these things.
lots of dull bands and chains
Offline Ernie
  • I woke up without a toe tag, I'm in for a great da
« Reply #3 on: April 05, 2005, 03:30:25 pm »
Please keep us posted with your usual quality pics.
Ernie
Offline Ianab
« Reply #4 on: April 05, 2005, 06:26:30 pm »
I have seen that planer sled idea too... looks like a good idea,
but
This is the biggest of the slabs, and most are 20-30" wide.
Scott, thanks for the tip on the router bit, the one I've got is a straight bit, and I imagine it will leave small marks on the surface. But I just want to get it trued up enough so I can tidy it up with a belt sander.
I'll let you know how it works out  ::) :P
Offline Dan_Shade
« Reply #5 on: April 05, 2005, 06:29:16 pm »
hah, now that's a slab!
what's the plan to secure the slab before you run your contraption over it?  Not sure how hard it would be, but would it be possible to rig up one of the power hand held planers to a jig like you have?
I'm pretty lazy, and I see running a router bit over a board like that a very long, time consumig process
Offline Ianab
« Reply #6 on: April 05, 2005, 06:58:55 pm »
To secure the slab I'm planning to use gravity  :D
It's about 3" thick, and even dry it's pretty heavy.
For the smaller ones I will probably knock up a frame with some cleats nailed around the slab to stop it moving.
It's going to take a while to smooth it off, but it wont be hard work just running the mill frame up and down the slab.
Could probably do a similar job by bolting a handplaner on, but you may end up doing multiple passes if there is any serious cup or bow on the slab. At least with the router I can slow down and take 1/4" off some spots if need be and the 2" bit will do a fairly wide pass. I'll find out how well it works at the weekend  ;)
Cheers
Online beenthere
  • EIEIO
« Reply #7 on: April 05, 2005, 07:31:45 pm »
I'm curious what is going to keep that router with a 2" bit from wanting to jump out of the cut.  The sled looks a bit lightweight to me, if I am looking at it right.
I am thinking there will be a lot of resistive forces at work here (as evidence you are thinking the slab will be heavy enough to not move against those forces).
But I may be thinking wrong, and I do trust you have a better idea how easy that router bit will 'cut' through and level the wood slabs.
Anxious to hear how it goes.
Offline Ianab
« Reply #8 on: April 05, 2005, 08:17:06 pm »
Hi Beenthere
The sled has a few more bracing pieces to go on it yet, I believe it will be be pretty solid as it's all screwed / glued timber and ply. I didn't want it too flimsy as it could vibrate and chatter while cutting. I'll jump up and down down on it a bit as a test first  ;)
I still have to do the clamps that will hold it to the mill carriage. The slab should be OK sitting on some bearers, that can be shimmed to level the slab to the mill frame. While I'm not keen to hang onto the router freehand with that 2" bit  :o I think the forces invloved will be much less than running the 21" circle blade into a log.
Bottom line is.. It's a prototype.. so I'll see what happens  ;) :)
Offline UrbanLogger
« Reply #9 on: April 05, 2005, 08:47:55 pm »
It'll work for sure Ian--who cares if the router jump up as l;ong as it can't dig in  ;)
I surface big slabs on my 4'x8' welding table. I just lay the slab on it and tack weld angle that's a little taller on each side and put my 3 1/4 horse PC on a piece of 3/4" or 31/32" plywood a little more than twice as long as the slab is wide.
It don't take long and leaves a tearout fee finish that only needs a swipe or 2 with the scraper to really shine  ;D
Offline ohsoloco
  • Can we stay outside and play in the sawdust?
« Reply #10 on: April 05, 2005, 10:24:15 pm »
The latest issue of Wood magazine has a jig in it that is used for flattening big slabs...although not QUITE as big as Ianab's  ;)   It sounds like Urbanlogger's setup is similar to the one in the magazine, but with wood guides on the sides...but again, not QUITE as big  :D
Offline Ianab
« Reply #11 on: April 06, 2005, 02:39:50 am »
Got a bit more done tonight. Router is bolted in place and the rig is ready to mount on the mill.
Now if I can get home in daylight hours I'll set the mill up and give it a test. ::)
Offline Ianab
« Reply #12 on: May 14, 2005, 01:42:02 am »
Finally got a fine day at home to try this rig out.
It works well  :)
Surface isn't perfect, some small swirl marks and faint lines, but nothing that wont come out in a few minutes of belt sander work.
The business end of things
The finished result. Flat and thickness accurate to within 1 mm on each corner  :)
Next is to sand out the machining marks and see how it looks with a bit of wood oil on it.
Then find a couple of mates to haul the BIG slab out and finish that up.
Offline tnlogger
« Reply #13 on: May 14, 2005, 01:14:12 pm »
thats is a fine looking job there Ianab  8)
gene
Offline Gilman
  • !eliforp ym tide ot deen I
« Reply #14 on: May 14, 2005, 01:25:51 pm »
Ian,
Thanks for sharing, looks like it works great!
WM LT70, WM 40 Super, WM  '89 40HD
Cat throwing champion 1996, 1997, 1999. (retired)
Offline Ernie
« Reply #15 on: May 14, 2005, 02:27:43 pm »
Looks great Ian.  Lil must be real understanding to let you set up just outside the door like that.
What's the wood, Mac?
Offline Ianab
« Reply #16 on: May 14, 2005, 06:06:14 pm »
Yup it's Macrocarpa, and dont worry, thats outside my workshop, out on the back lawn, not the front door of the house. :D
I'll just run the lawnmower round with the catcher to sweep up the shavings the broom missed  ;)
Offline LIL
  • Gender: Female
  • Mini Offloader!
« Reply #17 on: May 14, 2005, 06:34:54 pm »
Quote
Its not me he's got to worry bout Ernie -  ;) We have NEIGHBOURS.  Mind you Ivan next door is always interested in what Ians up to.  So it hasn't been a problem.
Due to a self inflicted 24 hour bug I was unable to oversee the goings on - I could however hear it from the bedroom :D
Hobbies and Interests
Interests revolve around my partners love of sawmills! - Hence being his NUMBER ONE OFFLOADER - Myself - I like the smell of sawdust. If I had my choice I would have BIG MACHINERY - who wouldnt want would their own combine harvester and an 18 wheeler (Scania)
Offline Ernie
« Reply #18 on: May 14, 2005, 07:52:44 pm »
Lil, I thought that a little "hair of the dog" first thing in the morning was a sure fire way to cut the self-inflicted bug back to 12 hours :D :D
Offline LIL
  • Gender: Female
  • Mini Offloader!
« Reply #19 on: May 14, 2005, 09:39:17 pm »
 :D
Ernie I did get around to that "hair of the dog" - just it was 12 hours too late.  ;D
I am feeling much better today thou ;)
Saw Anywhere!
