I went over to the kiln this morning and tried a few different attacks on the problem and decided to change the wire harness that goes from the terminal block in the unit to the motor.It is 3-14, around 3' long and rated 105 celsius and I replaced it with a chunk that is rated 60 celsius.
While I was in the hardware store I met up with a freind that had a clamp ampmeter and he dropped by and did a test. The motor used 15 amp on starting and dropped down to a consistant 3 amps but the unit would shut off after 30 seconds again.
We grabbed one of the switches off of the two circulating fans and tried it again and the unit stayed on and now the Alder in the kiln is finally cooking.
I suppose I should have tried that last week but didn't even consider that both new switches that were sent out from Maine would be faulty.The odd thing is that one of the new switches that wouldn't run the fan in the unit,works to run the circulating fan in the chamber.All the motors are the same rating
The switch specs are
FL. amp- 3
Hertz DC 50/60
Delay 94
Trip amps -4.05
And I doulble checked the voltage with the meter and it is 220 at the plug.
