Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Drying Reclaimed Oak  (Read 2278 times)
Offline Swing_blade_Andy
  • Its like boiling water with a box of matches...
« on: February 01, 2005, 02:16:16 pm »
Last year I published some pics in a gallery from a bunch of Lock gates I reclaimed.
http://gallery55364.fotopic.net/c167030_1.html
I have now customers who will buy kitchen tables made from this timber and so I need to dry it very well and very low MC.
Any suggestions or experience covering timber that has undergone 180 years of seasoning in the sea. As you can see there is a lot of reaction between the salt and tannic acid (I presume), which produced a stain that resembles iodine.
Will this leech out with the moisture?
I have contracted with a local sawmill, which has a small vacuum kiln. They have about 1 cub meter spare in the next charge (which will be ash). Will my oak effect his ash if its dreid together? Is there going to be any different outcomes to fresh cut oak? Anyone know?
Andrew
Re: Drying Reclaimed Oak
« Reply #1 on: February 01, 2005, 03:33:48 pm »
looking for the thing to up load pics...
where do I look..
got to get used to the new format.
Andrew
Offline Paul_H
« Reply #2 on: February 01, 2005, 03:41:28 pm »
Hello Andy,
When you post you will see a "additional Options" button.Click there and you will see the right place to upload.
and we shiver when the cold wind blows
« Reply #3 on: February 01, 2005, 04:30:14 pm »
try again with the pics
hope it works
Andrew
Offline serg
  • http://www.vacuums.ru
    • www.vacuums.ru
« Reply #4 on: February 02, 2005, 01:21:00 am »
Hello! In vacuum dryers I dried an oak of 800 years which have lain in water. Thickness of 70 millimeters width of 550 millimeters, length of 2500 millimeters. 35 days, up to humidity of 5 %. Temperature of 58 degrees С . Sergey.
« Reply #5 on: February 02, 2005, 03:54:52 am »
Thats cool serg.. seems like a very long schedule.
Do you have any pics of the timbers... did you get the same stain? Did it come out at all or dull any?
What do you think about the affects on freach timber in the same charge?
Andrew
Offline Den Socling
  • Board Moderator
  • just wondering
    • PC Specialties
« Reply #6 on: February 02, 2005, 10:51:00 am »
hi Andrew,
I've vacuum dried reclaimed oak in 110 hours. I've also dried it with freshly cut White Oak in 176 hours. No problems at all.
There's some pictures at our website but they don't do the stuff justice.
http://www.pcspecialties.com/redoakwetHC.htm
Den
Offline serg
    • www.vacuums.ru
« Reply #7 on: February 02, 2005, 12:33:30 pm »
I probably badly understand about what there is a speech? The wet oak of 800 years which have lain in water dries difficultly. When it(him) saw that on air it(he) bursts. Or there is a speech about change of color? Sergey.
Offline Den Socling
  • Board Moderator
  • just wondering
    • PC Specialties
« Reply #8 on: February 02, 2005, 06:08:56 pm »
Sergey,
I have heard the same thing about reclaimed wood cracking as soon as it's sawed. I have received some that was so cracked when it got here that I took pictures before going into the kiln. Some cracks closed and I haven't seen new cracks when I take it out.
I don't understand your last sentence.
Den
« Reply #9 on: February 02, 2005, 06:18:38 pm »
Thanks Den
Sergey spahseebah par drook. troodniy rahbottaheet dah?
I'll give it a go and show you how it works. The Kiln operator has told me that he will use a cycle over 2 weeks.... Sounds a lot do you think?
My boards are 300x 45mmx 2.8m
and 130x130mm x 2.8m
Let us pray.....
Andrew
Den I think sergey was asking if my post was about change of colour as well?
Offline Hugh Darty
  • Hunting, Fishing, Camping,
« Reply #10 on: February 06, 2005, 11:54:14 am »
Andrew
Swing Blade,
The blue will stay. The only option I know of is bleaching, which may work for a short time and then return. As for the dring, you should have no problem. Reclaimed wood (previously milled, not reclaimed logs)usually can be dried fast ( lots of heat) and not have the same drying defects as green wood.
I was once in the reclaimed wood business (heart pine and oak) and saw the blue metal stain a lot. I also saw it a lot in reclaimed sunken logs. I assume it came from iron in the riverwater, it was worse in some rivers than in others.
Good Luck
Hugh (Sawtooth) Darty
Hugh
Offline serg
    • www.vacuums.ru
« Reply #11 on: February 06, 2005, 02:04:35 pm »
Andrew, hi! I dried such oak of 35 days of 70 millimeter. An oak of 800 years water of 45 millimeter I dry 18 days. Up to residual humidity of 5-6 %. A marriage(spoilage) is not present. Color does not vary. You to dry 130х130 millimeter an oak? You inform results? ??? Sergey.
« Reply #12 on: February 06, 2005, 02:19:31 pm »
Sergey
khahrahsho  par drook
Thanks for the tips Hugh
do you know whether the blue will come out and stain freash wood in the same load?
I will certainly post the schedule and the results when I get them in about 2 weeks.
Watch this space
Andrew
Offline Don_Lewis
  • dry kilns, heat pumps
    • nyle
« Reply #13 on: February 07, 2005, 08:05:37 am »
When you dry sinker lumber, you have to go very slowly and still expect a fair amount of degrade. Bacteria have been working on the wood and the strength has been diminished. As for color, that should be a plus as it is. Two weeks seems fast to me.
« Reply #14 on: February 07, 2005, 09:01:39 am »
Thanks for the advise Don.
I just dropped the timber off to the Kiln operator today. He said that he would cook it for 2 weeks under auto vacuum(he didn't know how much) with a temparature schedule starting at 45 degrees and steadily raising it to 75 degrees.
Currently the moisture is around to 38 -48% mark. I've put some fresh oak in with it as a bench mark test. I hope that I don't get any more degrade as its quite 'rustic' at the moment.
Cheers
Andrew
Offline serg
    • www.vacuums.ru
« Reply #15 on: February 07, 2005, 09:40:57 am »
 Andrew, hi! Haste is not necessary. Vacuum 0.09 temperature of boiling of water of 45 degrees. Look page of a site. These are simple dryers with a computer has made a mistake, a sharp mode the first day of 80 degrees. The ends of an oak have bursted, they give a moisture the first. Then I have placed a vacuum dryer and 3 days without presence of vacuum held temperature of 35 degrees, the ends of an oak have received humidifying own pair. For 4 days I have lifted vacuum and have finished drying. Dried up to 4 % of humidity. The oak dried in regular intervals and cracks were closed densely. I recommended to place them in glue a bar. I of 75  degrees do not put a maximum of 65 degrees. Let will be longer but quality. I wait the message. Sergey.        http://www.vacuums.ru/news9.html
« Reply #16 on: February 07, 2005, 03:32:07 pm »
Interesting stuff Sergei
Thanks for the link.. got a chance to try out my Russian again... Needs a lot of work I have to say.
Its much easier writing Russian using your alphabet than to use phonetic spelling with our alphabet.
Anyway. I got to Ireland for a week so I'll be off line for a while.. I'll check in when I get back and see if there is any news from the man cooking my timber. I hope that my man doesn't overcook it as you said that the ends burst.
See you all soon
Andrew
Offline serg
    • www.vacuums.ru
« Reply #17 on: February 07, 2005, 03:51:49 pm »
Good luck to you. Sergey.
Offline Hugh Darty
« Reply #18 on: February 07, 2005, 08:27:23 pm »
Sergey
Watch this space
Andrew
I would think that it would stain the fresh wood if it touched. I dont't think it would affect it otherwise.
Hugh
Hugh
« Reply #19 on: March 29, 2005, 09:01:20 am »
Well I promised to update you all after the reclaimed timber was out of the kiln.
The timbers had nearly 2weeks in a vacuum kiln with a temp cycle going from 45 degrees up to 70 and then back down. The results were very varied indeed.
Most of the timber was about 45mm by 250mm oak, which was been partially submerged in salt water for over 150 years. When the timber came out of the kiln, the degrade was fairly dramatic in some boards with lumps and twists which made the recovery poor. The moisture content going in was reasonable consistent at 45 –60% but when it came out the moisture was all over the place. Over 1/3 of the boards had lost next to no water at all as they were still reading 45-60%. The remaining 2/3 gave reading from 8% up to 25%, but strangely it varied quite a bit in the same board. Typically the ends of the boards which are mostly heavily stained indigo gave the lowest reading and the centre of the boards which were mostly unstained were still quite wet – 30+%
However I have now used a couple of the boards to build a kitchen table for a client who is overjoyed with the result as it is quite unique in their experience. The main characteristic was that the timber, which was clearly submerged, was as hard as anything I have ever worked with – I mean it’s in the league of Iron Bark from Nth Australia. I’ve destroyed planers and routers getting this table out the door. Here are some pics of the results
I am not sure that it really feasible to invest in more forced drying of these. Perhaps I should just cut them all to size (14 tonnes) and let it dry slow. At least it will not soak up as much money and I hope I’ll get a more even dry with less degrade.
Andrew
Saw Anywhere!
