It's Fixed!
As advised I took the muffler off and the first thing I noticed was the baffle had broken. The broken piece and some little bits were inside the muffler rattling around. Through the exhaust port I could see the top ring was stuck. Took the cylinder off and it looks like the piston hit some small metal bits probably from the muffler and pinched the top ring. I swapped out the piston and cylinder from the parts saw and it's running great.
Thanks to some great advice from the FF chainsaw guys,it's back in action!
Thank you,
DD
