Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Log Hauler  (Read 3493 times)
Offline 1953greg
Re: Log Hauler
« Reply #20 on: February 05, 2005, 04:42:59 am »
randy.
you can greatly reduce the torque to the winch mounting bolts if you turn the base of winch to the direction of pull.  that way the forces are 0* to bolt direction and not 90* as it would be if winch is mounted in upright position (base down) and pull is horizonal.  mount the winch as low as possible where cable will  barely clear top of front rail.  this wil reduce torque on mounts to near zero.  the forces will be like the winch is sitting upright on its base and cable is verticle.   i mounted vertically  (2) .5" x 2" x24" flat steel (2" heavy channel would work) to the outside of front rail and they extend about 8" above rail.  this 8" area is where the winch sits with its base facing rearward.  is that clear as mud?  1953greg
good day    greg
Offline Furby
  • Blurb....
Re: Log Hauler
« Reply #21 on: February 05, 2005, 09:12:25 pm »
Nope that's an equipment trailer I picked up. ;)
Don't really know if it was a mobile home chassis at one time or not, but I dout it.
Yeah, it works real good. After busting the 4x6 ramps by trying to UNLOAD with them, I bought a couple gal. steel guard rail posts, and no longer use them for unloading. ;)
With the cross members on there, the weight is carried to the frame more then the decking. A big plus in my book. Anyone that has rails can use this setup as well, with a few mods.
Once setup, loading is fast, and unloading even faster.
Offline DanG
Re: Log Hauler
« Reply #22 on: February 05, 2005, 11:30:22 pm »
Just a word of caution to those that have trailers with rails. :P  Most likely, those rails are an integral part of the frame.  If you cut them off, a 12 inch log will fold your trailer up like a hospital bed! :o
Offline Furby
  • Blurb....
Re: Log Hauler
« Reply #23 on: February 06, 2005, 12:52:41 am »
Or use my setup between the side rails. ;)
Offline Frank_Pender
Re: Log Hauler
« Reply #24 on: February 06, 2005, 11:54:26 am »
What i would like to see are some plans for a mini log loader like some of you folks have been able to acquire in Eastern Canada and the United States, for handling you pulp wood or small logs.
   I have been toying with the idea of useing a discarded backhoe unit and placing it on a duel axel system for loading into my F450.   For around the farm I would pull a trailer behing it with the tractor and load a log trailer I have.
  Has anyone built such an item?  The ten or twelve thousand is more than I wish to put out for a factory loader.
Offline DanG
Re: Log Hauler
« Reply #25 on: February 06, 2005, 12:16:22 pm »
I don't see why a good fabricator couldn't build a Metavic-style loader for their trailer. Unfortunately, I'm not a good fabricator. :'(  I see no reason that a backhoe boom couldn't be used, but it would be sorta heavy.
I've also used an ordinary lift pole on a 3-pt hitch to load some pretty hefty logs.  They only cost about $100, so anybody with a tractor oughta have one, especially if they don't have a loader on the front.
Is anybody here using a wrecker truck to retrieve logs?  I frequently see them for sale for $3500 or so, wheel lift and all.  Some of the wheel lifts will pick up 5000lbs and could be used like a forklift to load a low trailer.
Re: Log Hauler
« Reply #26 on: February 06, 2005, 02:41:19 pm »
That is my feeling too, Dan, about the backhoe attatchment, weight.   I guess I am just tooooo tight with the pennies to just turn someone lose in a fab shop to build what I want.   I always seem to want something for the least amount possible.  If I keep waiting and watching I may well find what I am looking for, but will most likely be way toooo old to appreciate what I found, let alone be able to use the DanG thing.
Offline Ironwood
    • http://www.branchandburl.com
Re: Log Hauler
« Reply #27 on: February 09, 2005, 11:41:55 pm »
Frank, I have sampled several options as to loading log for the "capitally $ challenged" and the best bang for the buck is a log arch for the big  butt logs and a 1 1/2 ton bed mounted utility crane for the 1000-3000 lbs. logs. I have two cranes, one fairly heavy older telescoping unit w/ a honda hydralic power unit, and a 12 volt over hydrualic Ventoro brand unit both have power up-down/ swivel left-right and winches. They are base plate mounted so I can load unload them from trailer tongues or the back of my 12' flat bed. I use two "farm style" or "high lift" jack as outriggers (more verstile than fixed mounted arms). They really work well and I have about $2000 in each crane and a friend built the log arch for me on barter, it looks like a future forestry "hugo", which by the way are OUTSTANDING products. They ar ewell engineered and plenty strong yet not overly heavy for the hand moving of the arch sometimes necessary. I have tried the dead drag methods and the over the side rolling method previously mentioned, they work but are just too time consuming, well and i should also mention the 7000lbs soft maple log that hit the deck of a tandem trailer last year from 12" up on the ramps.  I thought it was going to roll right off the otherside of the trailer into a house. The truck got stuck in the yard as the trailer tires sunk from the weight and because the lack of tire chains for truck (left them at home)  the half frozen ground I just sat and spun. Then fortunately I was close to home as my heavily built tandem with no brakes and 12,000 lbs of trailer and log pushed me home. New year, newer heavier truck, newer legal trailer with brakes, a few cranes and loaders later I am in better shape and not risking everything I own for few good "free" logs. ;D learning more everyday!
Offline Randy
Re: Log Hauler
« Reply #28 on: February 10, 2005, 08:33:33 pm »
OK, I hauled my first logs on my new trailer this afternoon. Worked so good I wish I had of had it set-up 3 months ago(Keep in mind I am just getting started and only want this sawing to be part-time. I put a 3200lb hand winch on a custom built bracket on the front. I loaded 5 pine logs from the side, had to cut them to length, working by myself (single handed--all it takes to operate the winch ;D)  in 25 minutes, but wasn't trying to break any records. Man, I can't wait till tomorrow to go get some more. Like A child with a New Toy :D.
Saw Anywhere!
