HELLO MY NAME IS CARL WINNIPEG MB CANADA
I HAVE BEEN FOLLOWING THE VAC DRYING THREADS FOR QUITE A WHILE. VERY INTERESTING.
IAM A WOOD TURNER AND WOULD LIKE TO GET SUGGESTIONS FOR MY NEEDS EG DISCONTINIOUS VAC DRYING OF BOWL BLANKS. WALL THICKNESS 1-1 1/2 IN USING ELM ASH OAK ETC.
I HAVE A GAST 1/4 HP ROTARY VANE PUMP I USE FOR VAC CHUCKING ON MY LATHE. COULD THIS BE USED....OR HOW ABOUT AUTOMOTIVE A/C UNIT... CHAMBER WOULD BE 14-15 DIA HD PVC WATER/SEWER PIPE. HEAT.. CONVECTION AT NORMAL ATMOSPHERIC PRESSURE. DRYING TIME IS NOT AN ISSUE, WOULD BE MANUAL OPERATION. WOULD THESE SMALL PUMPS BE ABLE TO GET LOW ENOUGH VAC TO LOWER TEMP OF WOOD.. BOWLS WOULD BE HEATED TO APPROX 110 F. CHAMBER WOULD BE APPROX 5FT LOG AND HOLD APPROX 10-15 BOWL BLANKS. SOME OF THE BLANKS WOULD BE GREEN SOME AIR DRIED. THANKS CARL
